Old 03-13-2015, 11:25 AM
Starcrash Starcrash is offline
Default PSA: Use Cut instead of Delete when conforming
Maybe you all already do this, but I just had kind of a "Aha!" moment when I realized that I've been doing it wrong all these years.
Bottom line: if you have automation in your session, it's better to use Cut (X), instead of Delete in Shuffle mode when re-conforming to new picture changes.
Deleting automation breakpoints can easily cause unexpected weirdness, like a long slow ramp up to the next or previous breakpoint.
Pascal Garneau | IMDb
Old 03-14-2015, 01:28 PM
cananball cananball is offline
Default Re: PSA: Use Cut instead of Delete when conforming
Great tip. I've definitely screwed up my automation in unexpected ways like this.
Does using cut create new breakpoints on the edges?
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
Old 03-15-2015, 04:00 AM
joachim's Avatar
joachim joachim is offline
Ref Guide, p.1018 :
"If the Cut command is chosen, anchor breakpoints
are created at each end of the selection, and the automation
slope on either side of the cut data is preserved,...."
"If the data is deleted by pressing Backspace (Windows)
or Delete (Mac), the automation data is removed,
and automation values span the gap between
pre-existing breakpoints ... ."
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 03-15-2015, 05:35 AM
Man this explains so much.
Seems like we should never use delete to remove clips.
Ken Wilkinson
Old 03-15-2015, 05:53 AM
joachim's Avatar
If the track view is set to waveform, it should not make a difference between X and Del, but X is safer.
Old 03-16-2015, 09:58 AM
It really depends on where your breakpoints are located and where you make the edit, but I'd say it's generally safer to always use Cut instead of Delete whether conforming or just editing.
HTML code is On
Re-Conforming and PT 11 MoreMe Post - Surround - Video 3 11-17-2013 09:36 PM
Conforming 23,976 to 25 Alexander K Post - Surround - Video 3 12-20-2012 08:09 AM
Conforming hef Post - Surround - Video 11 07-03-2008 11:53 PM
Conforming vs. OMF All Ears Post - Surround - Video 9 01-24-2004 04:34 AM
In case delete region, my PT 5.1.3 delete all regions on track. What is it? kwarkot Post - Surround - Video 0 12-04-2002 12:38 AM
