Pro Tools Window 'Memory'
Hello guys,
After changing my two computer screens recently, PT no longer remembers window position and size. I've used 2 screens for almost as long as I've used PT (from version 4 or 5), with various screens, and this is the first time I've seen this. Whenever I open a session, I have to manually stretch / resize the GUI to fit both screens. Before, I only had to do that when creating a brand new session (which I hardly do anymore, because I use templates). Is there anything I have to do to make PT remember GUI size and window positions? I use a GTX950 card with Samsung monitors. The correct drivers are installed. Any light on this would be welcome. Thanks.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
Re: Pro Tools Window 'Memory'
What used to work was placing the windows as you want them and then closing them with Alt+F4.
Or Bob Nagy's Skooch, if you can find it and it will work on W10.
Mr. Weed, do you know the Mac equivalent of Alt-F4? Is it Command-F4?
Brian See profile page for system details |
No that won’t translate
Isn’t this a system pref?
On high Sierra didn’t this happen? I honestly don’t know my last Mac OS was 10.10.5 🤩 https://www.google.com/amp/s/www.mac...3515967/%3famp
Memory location window bug | Fritz | macOS | 4 | 03-15-2015 05:08 PM |
Memory location window missing | foggch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-15-2010 09:19 AM |
Memory Locations Window Help!? | Julian S. Pierce | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-28-2010 06:09 AM |
Can't Find my Memory Locations Window !!! | holden | Pro Tools TDM Systems (Win) | 1 | 09-19-2006 09:15 PM |
using memory location window | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-14-2002 10:36 AM |
