Sticky Rubber Pieces on Control 24?
Has anyone ever had the rubber pieces (bottom hand rest and side pieces of console) become sticky?
Ours is like the rubber has turned into a glue. All digi could tell me, is that they will look into the replacement parts. But we had to replace the power supply that had burned out, and all I could think of was maybe the heat screwed up the rubber permanently. I don't know. Anyone?
[email protected] www.jayriggs.com www.fifty-fiftymusic.com Turn Me Up!™ – Sign Up Now to Bring Dynamics Back to Music (www.TurnMeUp.org) |
Re: Sticky Rubber Pieces on Control 24?
Yeah ,mine's the same and there's nothing worse than having sticky ends! All jokes aside,the arm rest and the two side end trims are as tacky as! I've also had to replace the power supply at my own expense and touch up the solder joints on the monitor section D sub output board to get the intermittent left channel (speaker) working again. Might email Digi myself to find out about parts.
Cheers. |
Digi does have the front and side parts. They're like $150.00
Not a bad price, but since I already had mine torn apart, I bought this stuff at Home Depot called Krud Kutter, and with a scrubbie from the kitchen sink i stripped the "rubber paint" off in about 20 minutes. Then I used black matt spray paint and painted them. then matt spray varnish. Takes a wile between coats, but ended up looking great.
Yeah same problem here. Got a custom console made which at least gives me a nice armrest and covers that bit!
I'd be worried, in my climate of replacing these parts and having the same prob. in a year or 2... Like the paint job idea! Cheers, Hammers. |
Rubber Soul | tucum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 46 | 11-15-2021 09:12 PM |
Control 24 sticky solution? | primomusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 04-04-2013 06:33 PM |
Cleaning the Rubber Pad | laki | ICON & C|24 | 2 | 09-05-2007 03:57 PM |
Little Rubber Feet be gone! | gibson_sg | ProControl, Control|24, Command|8 | 3 | 06-15-2005 10:27 PM |
Control 24 Sticky Faders | Flanders | ICON & C|24 | 3 | 07-16-2003 01:40 PM |
