Old 07-11-2016, 08:37 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Default still no shortcut for "rename track"??
seriously? am i missing something. talking on a mac (yosemite).
It's not available in any of the menus so i can't make a custom key command?
anyone?
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 07-11-2016, 08:56 AM
Default Re: still no shortcut for "rename track"??
http://protools.ideascale.com/a/dtd/...cut/26885-3779
http://www.richbreen.com
Old 07-12-2016, 07:18 PM
Thanks, Rich. I guess I need to learn more about programming mouse strokes in keyboard maestro.
Ben Rubin
benrubin.com
Old 07-13-2016, 12:30 AM
remute remute is offline
As a workaround, if you're on Mac, you can go to System Preferences>Keyboard>Shortcuts>App Shortcuts and add Pro Tools to then assign a keyboard shortcut yourself.
Old 07-13-2016, 04:24 PM
Can't do that because that command doesn't exist in any of the menus that work with system Prefs. Unless I've been missing something for 15 years.
Ben Rubin
benrubin.com
Old 07-14-2016, 03:30 PM
Ben Jenssen's Avatar
When renaming more than one track there is the shortcut for moving to the next track when you're in the renaming dialogue box: command-rightclick (mac), but I guess you know that.
Old 07-15-2016, 06:17 AM
Yes Ben thx. You can also do command-return or command-arrow keys.
Ben Rubin
benrubin.com
Old 07-15-2016, 06:25 AM
Originally Posted by Benny_Cha_Cha View Post
command-arrow keys.
Yes. I wrote "rightclick", I meant of course arrow-keys.
Old 01-30-2018, 01:13 PM
Boborr Boborr is offline
I also find this incredible. You can call up the New Tracks dialog, (ctrl+shift+n),
then use the keyboard to select mono/stereo, track type, samples or ticks, but you then have to leave your keyboard and use your mouse to enter the track name(s)???
An extra field in the New Tracks dialog would do the trick. I mean, we have to name our tracks, right??
2 cents,
Bob
Old 01-30-2018, 01:35 PM
Create the tracks, double-click the first track and name it, then command-rightarrow and name track number two, and so on. You only use the mouse once.
Alt-Shortcut to reach "Edit" > "Automation" > joachim Windows 0 10-13-2014 08:14 AM
Difference between "Go to Song Start" and "Return to start of session" shortcut pericoloso Pro Tools 10 2 09-22-2013 12:44 AM
"New MIDI Track" Shortcut? Andy R macOS 9 06-02-2013 03:56 PM
"Assertion..." problem while trying to rename a file samplaire macOS 1 03-08-2013 03:46 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
