BUG: Elastic Properties Pitch Shift AAE error -9411
Tried to pitch shift two vocals, one up +5 cents, one down -5 cents. I am not showing red at all (like when you stretch an audio file too long, etc) because I am not stretching audio. I simply enabled polyphonic elastic audio, opened the elastic properties menu, then changed the cents on each file, then pressed play. It plays for about 2 seconds and then gives me an AAE error -9411. My work around was to disable elastic audio and commit the changes to the track. That seemed to work, yet because of this I couldn't preview the track in real time.
Anyone else having the same problem? Anyone want to test it out and see if it is a true bug? My setup: -MacBook Pro 15” Retina, Mac OS version 10.9.2, 2.6 GHz Intel Core i7, 16GB 1600 MHz DDR3 Ram, 1TB internal flash HD -Sonnet Echo Express Thunderbolt 2 Chassis -Pro Tools version 11.2, HDX Card connected to HD I/O -Pegasus J2 Thunderbolt SSD HD for session data -WD MyBook USB 3 HD for VI Samples -Other devices connected include: Apple Keyboard, Trackpad, MAudio Uno Midi->USB, MAudio AxiomPro 49, and my iLok 2, all connected thru a USB multi port hub. |
Re: BUG: Elastic Properties Pitch Shift AAE error -9411
Same here...
Any one else? |
DAE Error 9411 | GS-DK | Pro Tools 10 | 8 | 11-12-2014 04:27 PM |
Elastic Properties Pitch Shift Value not Retained | anklescrape | Pro Tools 11 | 0 | 06-29-2013 10:04 PM |
Where's my Elastic Properties? | Reesho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-13-2010 06:32 AM |
Pitch Shift VS. Elastic Pitch | StinkyStan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-24-2009 09:15 AM |
How Do I make Elastic Pitch shift gradually? | products7074740 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-03-2009 03:43 AM |
