Old 07-15-2014, 09:14 PM
adrianrobison adrianrobison is offline
Default Yet another bug AAE error 9480
My Setup:
Late 2013 MBP Retina 15” maxed out. HDX in TB2 Sonnet Echo Express 3 with HD I/O
Grouped all, made some edits, basically just rearranged the song. I’ve got audio, aux, master, and instrument tracks going on. Pressed spacebar to playback the audio and got a AAE error 9480. Searched online and couldnt find this error explained anywhere, not even on Avid’s site. It only occurs on the part of the audio that I sliced (in my case the song’s outro). Everything before it plays just fine.
Anyone know what this is?
Also, I’ve owned HDX for about a month now and have noticed that it has so many bugs. This is very disappointing considering it is their flagship model. But hey, I’m trying to be part of the solution, not part of the problem so I’ll keep posting these errors as they come.
Old 07-16-2014, 06:17 AM
Stig Eliassen's Avatar
Default Re: Yet another bug AAE error 9480
Sorry to hear about your issues with PT 11, but I'm glad you're reporting this in a constructive manner. That's what we need around here to move forward.
Which version of PT is this? Was it an edit group or a clip group?
Avid Knowledge Base #1
Avid Knowledge Base #2
Maybe those articles above can help in your search for a solution.
Old 07-16-2014, 12:58 PM
The version of Pro Tools was v 11.2 (the most current as of today) along with Mac OS 10.9.2. I was using edit groups, not clip groups. My solution that I found worked best was to close the session and reopen an older version of the session. After making those same song arrangement edits, the error did not come back. I did not shut down Pro Tools or the computer before reopening a session.
Old 07-16-2014, 03:50 PM
I see.
Thanks for the update. Let us know if this happens again.
Old 08-21-2015, 12:41 PM
derekvh derekvh is offline
Originally Posted by Stig Eliassen View Post
I see.
I found this when i get AAF files from the Picture department that have bad fades like the entire file has a fade -When I throw the file out or delete it off the timeline all is well. i wasnt able to adjust the fade so i had them resend the file.
Old 02-15-2017, 03:54 PM
Will Hicks Will Hicks is offline
im getting this. most recent version of pt 12
Old 03-05-2017, 10:00 AM
alfst28 alfst28 is offline
I see this is quite a dated thread but, I've just got this error in the same way as the original contributor.
After going through some 80 active audio tracks (lots of auxes too), I've noticed a couple of spliced fades that were cut when I took a chunk of the song out for the rearranging purposes. It's a whole-band-together type of tracking so the kick is not exactly on the grid line. In any event, some fades left overs were just sitting there and after removed from the timeline, the error is gone.
No need to reopen the session.
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. kieran.mia macOS 1 01-29-2013 01:39 AM
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error EricMulhern macOS 1 11-20-2011 05:39 PM
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 Karma180 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-05-2011 07:46 PM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
