Old 07-21-2005, 01:59 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 6.4.1cs4 Updates for MIX Systems
What's Fixed in Pro Tools TDM 6.4.1cs4?
Pro Tools TDM 6.4.1cs4 for Pro Tools|24 MIX systems on Mac OS X 10.3 & Windows XP contains the following:
Fixed: Levels in the Pro Tools mixer could vary by 12dB when interfaces were connected to more than one MIX card (Items # 58105 and 58299)
In order to fix these problems, +6 dB fader gain mode has been disabled in Pro Tools 6.4.1cs4, which will now only operate in +12 dB fader gain mode. Please note the following —
  • Any +6 dB or pre-Pro Tools 6.4 session opened in Pro Tools TDM 6.4.1cs4 will play at the correct levels.
  • Volume level compatibility with pre-Pro Tools 6.4 versions of Pro Tools is maintained for all volume levels below +6 dB.
  • Any volume levels written above +6 in a +12 dB session will play properly in Pro Tools 6.4 or later. Volume data written above +6 dB will be truncated (moved to +6 dB) if the session is opened on a pre-6.4 version of Pro Tools This is the same behavior as all versions of Pro Tools 6.4 and later.
  • You may still "Save Session Copy in…" as a +6 dB session, with the same truncation behavior, as with all versions of Pro Tools from 6.4-> 6.9.x. The result will be no different than just opening the session in a pre-Pro Tools 6.4 system.
Fixed: Scrubbing or Shuttling a 9-Pin Device Did Not Smoothly Update the 9-Pin Device (Item #51198)
  • When using either the control surface jog wheel or the “Shuttle” Numeric Keypad Mode, 9-pin devices would start and stop during shuttle and scrub operations.
Available for download from the Support->Downloads->Index of All CS Fixes:
http://www.digidesign.com/download/cs/
and here:
http://www.digidesign.com/download/cs/641cs4/
Administrator
Pro Tools 7.3.1cs4 Updates for All 7.3.x Systems reelzman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-28-2007 06:32 PM
Pro Tools 7.3.1cs4 Updates for All 7.3.x Systems Avid Technical Alerts 0 07-26-2007 09:56 AM
Pro Tools HD 7.1cs4 Updates Avid Pro Tools TDM Systems (Win) 3 02-21-2006 05:43 AM
Pro Tools 6.4.1cs4 Updates for MIX Systems Avid Pro Tools TDM Systems (Win) 0 07-21-2005 01:59 PM
Pro Tools 6.4.1cs4 Updates for MIX Systems Avid General Announcements 0 07-21-2005 01:57 PM
