Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 01-18-2020, 11:16 AM
Barbershop Barbershop is offline
Default 002 to Mac Mini (2014)
Hey guys,
I am a little confused since I have never used firewire, well not since 2003, but the mac mini I have is the older version, I have the 002, and want to hook it up, but it isn't just a straight firewire is it? do I get a firewire to thunderbolt?
the mac mini has Thunderbolt 2 plug...
so do i need a firewire out of the 002 and then a converter to thunderbolt 2 then thunderbolt 2 wire?
or is there a firewire to thunderbolt wire?
thanks in advance...
Old 01-18-2020, 11:20 AM
Default Re: 002 to Mac Mini (2014)
Getting firewire connectivity is not the issue. 002 driver support is. Do you have a 002 diver compatible with your macOS version? If not it's a door stop.
http://avid.force.com/pkb/articles/e...02-003-Drivers
Old 01-18-2020, 11:26 AM
If you can find a compatible driver then you just use an Apple Thunderbolt to Firewire adapter and connect that to a a third part Firewire 800 to 400 adapter or Firewire 800 to 400 adapter cable. There are lots of old discussions on DUC about that that you can look at.
Old 01-18-2020, 11:49 AM
ok...so I can just download one from there or nah?
I'm a little confused sorry..
Old 01-18-2020, 11:50 AM
ok so apple thunderbold to firewire adapter but which one firewire 800 or 400 adapter? what is the difference?
Old 01-18-2020, 12:07 PM
You need to look on that page and see if a 002 driver is available for your macOS version.
Old 01-18-2020, 12:12 PM
Which one what? You should be able to use any high-quality/good brand Firewire 800 to 400 adapter or Firewire 800 to 400 cable depending on how you want to do this, how long a cable you need and if you still have an old FW400 cable etc. Knock yourself out... Amazon or other reelers have lots to choose from.
Old 01-18-2020, 12:51 PM
ok thanks...
PT11 on Mac Mini 2014? delasnarce Pro Tools 11 25 01-07-2017 12:27 AM
Mac Mini 2014 actual Pro Tools HDX & HD Native Systems (Mac) 3 04-16-2015 12:35 PM
Help me decide on a used 2014 Mini Mac lydpik macOS 5 12-15-2014 01:34 PM
New Mac Mini Oct 2014 Obsidian Dragon macOS 45 10-23-2014 09:19 PM
Mac Mini 2014 Marcel Risberg General Discussion 24 10-19-2014 05:42 PM
