Old 04-07-2018, 10:32 PM
bobo mark bobo mark is offline
Default Pro Tools on Dell XPS 15 9650 (2017)
Hi:
Anyone running Pro Tools 2018.x on Dell XPS 15 9650 (2017)?? I'm long long time Mac Pro Tools user.. But really really hate MacBook Pro now days.. the DELL XPS 15 can have 32gig RAM... many I/Os... that why I was thinking to try...
thanks
Regards
Bobo
Old 04-08-2018, 09:24 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Pro Tools on Dell XPS 15 9650 (2017)
Can you return it? If you get 30 days I would get it, remove the bloat, do ALL the optimizations here, load on PT and see how you get on. If it works, keep it. It sucks, take the Dell back to factory and return it.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-08-2018, 10:05 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I5 will work, I7 is better. I would check and see if the motherboard/chipset will accept an upgrade processor in case you need more power later. You will want to make sure to use SSD system drive and high speed or (best)SSD audio drive. I'm using a quad core I7 in my desktop, but I also have PT Native on two laptops, one I7 and one I5. The I5 runs a few less tracks/plugins but laptop processors are more limited that desktops so unless you are doing large sessions/ a lot of video editing/ a lot of VI's you may never notice any problems if you do all the optimizations , etc
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 04-09-2018, 07:16 AM
manichouse manichouse is offline
I've been running PT HD on an XPS15 9650 i7 for a year now as a mobile rig with an Apollo Duo MKII and an MBox3 Pro. While this is more of a "scratch pad" rig for me, I have at times finished entire projects just on the laptop instead of dumping them to my larger HD rig. I've mixed a few docs and spots on it as well in a pinch and it worked just fine. At high buffer settings it can nearly hang with my slightly older i7 3930k 6 core workstation. At lower buffer settings, not so much... but certainly usable. I would absolutely wipe it and remove the bloatware. Also, make sure you are on the latest bios, networking, and thunderbolt drivers... the original shipped configuration was a dog and completely unusable for daw work until the newer drivers and bios arrived. Good luck!
Martin Trum
Old 04-09-2018, 06:35 PM
Thanks so much... I just find out XPS 15 9750 (2018) 6 cores will ship soon. but the 9650 with 32 gig RAM ,1T is on sales for $2200. Thinking to wait more or buy the 9650 now..
Regards
Bobo
I went back to Pro Tools 10 HD Accel in 2017 jacko Pro Tools TDM Systems (Mac) 17 06-19-2018 02:26 AM
Namm 2017 New pro Tools Hard & Soft ? Say Your About... zavid General Discussion 4 11-08-2016 07:50 AM
any 9650/350 user here ?????? WalterRipley Pro Tools TDM Systems (Mac) 0 03-25-2001 09:16 AM
Compatability - 9650 233 Mhz and Pro Tools 5 Evolution Pro Tools TDM Systems (Mac) 0 03-21-2000 06:20 AM
