Old 06-26-2008, 12:44 PM
Shefi Yishai Shefi Yishai is offline
Default PT HD 7.4cs6 get info shows the wrong version.
After installing the 7.4cs6 updater (OS 10.4.9) the "get info" for the application shows the right creation date but the version reads 7.4cs5!
Talking about that.... I think it is about time to change the date on the PT launch window to "Digidesign 1991-2008"
Shefi Yishai
Old 06-26-2008, 05:06 PM
Halstein Halstein is offline
Default Re: PT HD 7.4cs6 get info shows the wrong version.
Yepp. Same here.
I still got a 7.4 on a 10.4.11 system....as a trusty version, if 7.4.2 on 10.5.3 fails... I believe that the 7.4cs6 version installs correctly - just the infofile from Digi that's not updated...
pthd9-pt11
imac 14,1 / imac 7,1 / macbook air 5,2 / self-built hackintosh with gigabyte z97x board + quad i7-4690
Old 06-26-2008, 11:24 PM
the dude's Avatar
the dude the dude is offline
CS updates often do not update all parts of the software
but usually only installs or updates the updated software components and extensions
If you have installed previous updates, some file versions may not change. This update installs the following files:
DigiDal.kext (v7.4cs6)
Pro Tools HD.app (v7.4cs5)
DMC.framework (v7.4cs4)
FFmt.framework (v7.4cs4)
DAE.framework (v7.4cs3)
DHS.framework (v7.4cs3)
Dynamics III.dpm (v7.4cs2)
D-Control.bundle (v7.4cs1)
HWC.framework (v7.4cs1)
http://www.studio-techservices.com
าำ
[email protected]m
Mitch Berger Tech Services
We service ALL Avid products no Problem
HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything
ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around
inquiry using link above
Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear
Old 06-30-2008, 12:34 AM
Thanks for the details.
I posted it because I wanted Digi to fix it.
I still think that if the name is 7.4cs6 this should be the name in the "get info" as it used to be in all previous cs updates
(It seems that Someone simply forgot to do something....)
(What about someone who had" an old" cs5 on a separate partition?)
Shefi Yishai
AutoWrite to punch - preview shows wrong results since PT9.0.5 Hanswurstlsepp ICON & C|24 21 11-08-2011 08:01 AM
Midi info playing on wrong instrument track bruce lang Virtual Instruments 4 03-16-2009 07:21 PM
Accidental PDC or wrong delay-info? Wasaia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-21-2008 08:58 AM
Digi:Info on G4 compatability wrong? BRYAN SAVAGE Pro Tools TDM Systems (Mac) 1 01-23-2002 12:51 AM
Wrong ProTools info on Apple.com? mike connelly General Discussion 0 10-03-2000 08:37 AM
