Quicktime at 24 fps reads 24.x in PT HD
Hiya
I get 24 frame QT DV picture from the avid assistant. He uses FCP to output, then he conforms the DV to 24fps. We have used this method for a few years on various films and the QT always agrees with itself.... In PT 8 HD the QT region now says 24.2 or something. I don't know if the actual play back speed is being affected. The accompanying sound omfs all match perfectly. if you open the QT IN QT and get info it says 24fps with no variation. It is also verifies as 24fps in FCP. I know that these avid assistants are ROCK SOLID. The only thing that's changed is me going from PT7 to PT 8. If tech support is interested I can create a small clip of the DV and drop it somewhere.... thanks scott ps - my pt session settings are - timecode - 30 fps feet frames 24. (it matches their visual window code as well)
[img]/images/graemlins/tongue.gif[/img] <<<<< in the psychiatric emergency handbook this is bad news. Last edited by smlworld; 05-26-2009 at 07:56 AM. Reason: adds |
Re: Quicktime at 24 fps reads 24.x in PT HD
FCP (actually Quicktime) has a problem where it won't actually output at the correct frame rate unless you specifically set it. Even then I've seen some oddness with it. Verifying in QT and FCP will also give you incorrect info, as they both use the QT engine - so the video may actually be 24.xfps, but QT and FCP will both read it as 24P. Try opening it in VLC or other media transcoder (MPEG Streamclip is another good one) and I bet you'll see a different frame rate. |
Does PT9 reads directly from OMF-media? | Arno Peeters | Post - Surround - Video | 4 | 02-02-2011 02:21 AM |
Installation reads not enought RAM | Metalhead41 | Pro Tools M-Powered (Win) | 1 | 11-30-2009 09:41 AM |
partion reads transfer only? | sterndrup | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-05-2008 01:47 PM |
Macpro reads RAM incorrectly | sonny7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-04-2008 02:11 PM |
Athlon 3000+ reads as a 1.4 ghz | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 11-12-2003 10:54 AM |
