Appsets for CB 10 not working
Just installed the Appset CB 10.5.1. It shows up on the 2 small LCD on the Master and Automation module but none of the buttons work. Seems like cubase is not responding to Eucon command...Faders and transport work fine.
Re: Appsets for CB 10 not working
Can you try and program a single key like play and see if it works ?
Hi Eddie,
After uninstall/reinstall the Eucon Workstation Unified for S6, it seems to work now. Btw, I will need to add the ipad for remote controlling PT while tracking drums. I remember a while back you mentioned its OK to install S1/S3/Dock/Control AND S4/S6 on the same computer. Is this still the case ? Thanks |
Yes, you can add a single Avid Control EUCON device via EuControl to an existing S4 or S6 system. Simply re-run the same version Unified Workstation EUCON Installer and tick both:
S1 / S3 / Dock / Control / Artist Series S4 / S6 Workstation best, Jeff |
MCPro: Nuendo7 + Nuendo8 AppSets | niekbeem | System 5 | 2 | 06-28-2017 10:47 PM |
Copy appsets? | niekbeem | System 5 | 2 | 07-13-2015 06:44 AM |
XMLs (Appsets) for Logic Pro X, Cubase, and Nuendo on Mac now available | Kyle Splittgerber | Avid S1, S3, Dock and Control App | 0 | 05-18-2015 10:37 AM |
