Error message with PT8 M-power
I have gotten this horrible error message (error - 9073) a few times in prior recording sessions with the current set up that I have now. However, this time I cannot seem to fix it. Usually I could solve the problem by just adjusting the buffer sizes. No luck this time. Currently I am multi-tracking 3 tracks to a profire 2626, with no plug-ins. Two XLR mic connections and one DI connection, via XLR. Here is my set up:
Mac Mini 2.53Gh, 4GB ram Profire 2626 - connected to mac via firewire 800, with converter adapter from 800 to 400. Lacie rugged 320GB - connected to mac via USB 2.0. My first thought was update drivers and protools. Everything was up to date. Next, I thought that my connection between my Lacie and Mac was too slow. I run protools off of the Mac HD and write all of the files to the Lacie. To test this, I moved my current recording project from the Lacie HD, to my mac desktop. Same error message. Then I tried uninstalling protools 8.0.4 and reinstalling it. Same error message occurred after reinstalling and starting up my project again. I think that my problem lies somewhere in my connecting between my profire and the mac. This is why. As an experiment, I had the guitarist who I was recording not play his solo (the part we have been trying to record, but what attempts have been foiled by this error message), but instead just play a simple chugging pattern. No error message occurred. I deleted the tracks and had him play his solo this time. Error message pops right back up after about 5 seconds of recording. Not sure what the problem is. I do not think it is protools 8.0.4, but what I cannot figure out, is if it is the profire 2626, the connections, or the Lacie HD. Suggestions would be great please. Thank you |
Re: Error message with PT8 M-power
Pro tools does not support USB drives!!!!! Thats where your errors are coming from.
Use a firewire hard drive and Daisy chain it off the 2626 via firewire. |
In response to your other suggestion, does my external lacie rugged need to have a power supply in order to daisy chain it after the interface? Thanks |
You're not supposed to record to your internal system drive either.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Error message!! You are running out of CPU power. Remove some Native plug-ins... | Jmissy87 | Pro Tools 10 | 8 | 06-17-2013 06:51 PM |
You are running out of CPU Power! Error message (-9128), I have tried everything! | thatguy22 | Pro Tools M-Powered (Win) | 9 | 08-24-2011 01:42 AM |
You are running out of CPU Power! Error message (-9128), I have tried everything! | thatguy22 | Pro Tools M-Powered (Win) | 0 | 07-24-2011 11:14 PM |
A Message But Not An Error Message | RichrdC | Pro Tools M-Powered (Win) | 3 | 01-27-2008 06:57 PM |
Running Out of CPU Power Error Message | Maars | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-23-2007 10:08 AM |
