Digi 002 audio output issues
Just come across an issue with the audio output channels on my set up .
It's not only that it is lower in volume but the seems to be no bass frequency or very little in comparison to the other channel. I thought i just blew out my right bass bin on my speaker ,but then i put the same audio feed through another amp and speaker and it was the same. I tried adjusting the volume by mooning the signal on two channel and raising the right side by a few db's ,but it never changed, and still comes through lower on my digital recorder. Even when i solo just the mono KICK, the signal is lower in the right channel. I will be away for my set up for tomorrow for a few months so i am hoping for some help before then ,if not any help would be appreciated . thanks. OK i did a bit more sifting around and found out that the bottom output channel is not functioning properly channel in question is the (main R+2) no bass frequency coming for that. That is the problem here any ideas how to fix? Last edited by specnur; 03-22-2017 at 04:48 PM. |
Re: Digi 002 audio output issues
A couple of things to consider:
1-do you have balanced cables from the 002 to the speakers? If a balanced line loses either of the signal wires(tip or ring), it will sound 6db softer and have no bass 2-the 002 has 2 sets of outputs. One is controlled by the output volume knob on the front. The other set runs wide open(but is fine to use thru a monitor controller like the Presonus Central Station, Mackie Big Knob, etc) 3-if the 002 is truly broken(and it may be), then I would replace it. A used and working 002 is likely cheaper to buy than getting a repair. If you are on PT9 or higher, then you can move to any of dozens of interfaces, most of which will sound better than the 002
Thanks for the prompt reply.
I was wondering how much a new console would cost and i think buying something that i amused to rather than yarning something new at this time is probably the best move for me. Before that i will definitely check the wiring but i am sure i used a couple of different sets of wiring through the channel to with no change in issue . Pity i won't be able to do anything for the next few months as i leave for Europe ,but i will jump on this when i get back. Thanks again. |
Komplete Audio 6 Output Issues | bluebird | Pro Tools 10 | 1 | 12-17-2015 10:16 PM |
No audio output from digi 002r | Sandy Berman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2014 08:36 PM |
No audio output from Digi 001 | emulin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 01-07-2014 04:31 PM |
Mbox Pro Audio Output issues | MaddDogg41510 | macOS | 3 | 11-28-2012 08:34 AM |
Digi 002-using FW & core-audio drivers to output audio to mac WITHOUT using ProTools | DaveZ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 04-12-2012 12:53 PM |
