#21
Re: Pro Tools 9 deleted my files!!!!
bb |
#22
No, definitely not. When I rename to a final consolidated file I always remove the numeric sequence at the end, and at a symbol at the head of the file name. Eg. 'Kick In_03' becomes ... '++Kick In'. And for each new version of the file a symbol is added. I also went to the Finder to manually check and see where the audio files were, and had no luck finding them. The same thing happened to me again yesterday, and I took some screen snapshots, and have a bit more info. I also noticed I have no ability to save the corrupted session anywhere, as it keeps giving me the 'volume not mounted error' as a reason it can't save. Hence the error shows itself whenever Protools tries to Autobackup. Let me know where I can send the pictures, if they'd be any help. They show the error shown.....Protools showing consolidated files, and a window of Finder showing the files I consolidated with two of them being absent, the ones being shown in the error box. I won't have time to do any troubleshooting till next week sometime. I need to get this batch finished up first. Again I stress this procedure is not new to me, I have done things this way for almost 10 years now. The only errors I've ever had were during the Protools 5 to 7 era, when the renamed file would not take on the track name for some obscure reason. That was finally fixed in 8! Although it was more frustrating, than a hinderance, as I'd be renaming the audio file anyway. |
#23
I've just had a hunt around, and I do have a copy of my 'missing file' session (it did allow me to save), and a session file backup from just before the consolidate also. However I'm not sure that either of these things would be of any use to anyone, as I just spent an hour trying get it to lose the files again so I could post something useful and repeatable, and failed miserably. But to answer digi's questions:
Had just consolidated a BD drum edit, then moved on to other EA edits, a few minutes later I noticed the drum waveforms had disappeared, I tried to recalculate overviews and I got a volume not found error. Saved the session, quit, relaunched and all the consolidated drums (but no other files) had gone. Checked their location - was the normal audio files folder, tried a search both through relink and looked manually in the finder, but no files with those names existed. Quote:
#24
bb |
#25
That reminds me - I didn't rename mine at all. So unless these are acutally similar symptoms of different problems I don't think it's related.
#26
Actually, just re-reading what I wrote. I forgot to mention, that the last time this happened (yesterday). I did NOT rename any Audio Files at the time. I was going through the session from top to bottom, consolidating as I go. And I was made aware of the problem when Protools did its autosave.
#27
Just had the same on 8.1cs2!! Consolidated large number of files always changing disk allocation. 2 times of 10 i got 'error - 35 volume not found' and no sign of consolidated audio on drives. Meanwhile i can see this audio in session and actually play it. once i found files on a drive A while Pro tools definitely showed they belong to drive B
#28
I just had this happen AGAIN in 8.1cs2 after consolidating a drum edit.
Come on Avid, random deletion of audio files is not exactly acceptable behaviour for an industry standard DAW is it? Please sort this out ASAP. I can send logs and/or sessions if you need them. |
#29
Ok, I'm not sure if it's the same bug as what caused all the file deletions detailed here, but I have found a 100% repeatable way of causing this to happen.
1. Create a blank session 2. Create an audio track 3. Make a selection on the audio track 4. Hit consolidate (it doesn't matter that the track is blank) 5. Cancel the consolidate before it completes 6. Repeat the consolidate immediately, I used alt-shift-3 again rather than just the redo shortcut 7. On your newly created region, perform enough un-doable actions for the consolidate operation to fall out of the undo history (eg splice it 32 times) 8. Now try and create a fade on the audio. It won't render - and you'll start getting -35 error messages. Check in the finder, the consolidated audio file has gone! I can't honestly remember if on the previous occasion this happened I cancelled the consolidate at any point, but I definitely did this time around. I'd made an adjustment to the edit and forgotten to recreate the necessary fades, so I cancelled to do this then redid the consolidate. Does anyone else who had the problem recall if a cancel was used at any point? |
#30
I had similar issues and found that deleting the WaveCache.wfm and the Fade Files from the session folder stopped the bleeding.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
Pro Tools tries to re-link deleted files. Why? | sb_stefan | Pro Tools 10 | 7 | 11-23-2021 11:02 AM |
Anyone experience the "pro tools deleted my files" behavior in PT 10? | PeterScherr | Pro Tools 10 | 23 | 07-04-2012 11:35 AM |
PT9 Deleted my files too | nikdanger | Pro Tools 9 | 3 | 01-18-2011 08:27 PM |
DELETED FILES HELP | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-14-2006 11:35 AM |
My Audio files were deleted!!! What software to buy to restore the files.... | lucio matarazzo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-22-2000 06:45 PM |
