Old 02-12-2005, 12:50 PM
mytinycircus mytinycircus is offline
Default digi001 to digi002R upgrade playback engine issue
I traded my 01 in for an 02R and installed hw and sw (6.4 which I as already using with the 01 but reinstalled anyway) and when I try to open an existing session I get this message...
The last time this session was saved
the playback engine was "Digi001".
This playback engine is not currently
available. Wouls you like to open it
using the current playback engine
which is "Digi002"?
If I answer yes my system (XP SP2) reboots. If I try to create a new session my system reboots.
Anybody know how to fix this ?
LE 8 02R XP Home SP2
Intel DQ965GD
Intel Core2 Quad CPU Q6600 @ 2.4GHz
2GB DIMM DDR2-666
NVIDIA GeForce 7600 GS
XP Pro 5.01.2600 (SP3)
www.mytinycircus.com
Old 02-12-2005, 12:54 PM
Bastiaan Bastiaan is offline
Default Re: digi001 to digi002R upgrade playback engine issue
Uninstall ptle. remove all instances of DALWDM.SYS, and reinstall ptle from scratch.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 02-12-2005, 01:21 PM
Sadly that didn't work. I removed all instances of dalwdm.sys but still had dalwdm.inf and dalwdm.PNF present - Would that make a difference ?
Intel DQ965GD
2GB DIMM DDR2-666
Old 02-12-2005, 01:23 PM
What version of ptle are you running (or trying to....)?
What firewire card are you using? More important, what chipset is being used on that card?
I know it is 6.4, but what cs-version? I think only in the last (6.4cs9) the problems with SP2 are solved.
You probably didnt suffer from those because the 001 uses a PCI-card as where the 002 and 002r use a firewire connection. Thus suddenly firewire matters pop up.
What's that?
Bastiaan
Old 02-12-2005, 01:42 PM
I'm on 6.4.0.138 which came with the 02R - I'm downlaoading 6.4cs9 as I write - I'll see if that fixes it.
Intel DQ965GD
2GB DIMM DDR2-666
Old 02-12-2005, 02:29 PM
I removed 6.4 and drivers, downloaded and installed 6.4cs9 and still have the same problem. My firewire interface was a Digidesign approved one and I've been using if for years with Buslink drives and my DIGI001 so I doubt it's that.
My system reboots even if I try to leave LE.
Intel DQ965GD
2GB DIMM DDR2-666
Old 02-12-2005, 03:35 PM
for harddrives..ok. For digi001...no way. digi001 is a pci device, so it doesnt use firewire cards.
Make sure your firewire card applies to the compatibility Digidesign demands.
What's that?
Bastiaan
Old 02-12-2005, 04:02 PM
I removed all software and drivers and deleted all my digidesign directories and downloaded 6.4cs9 again and did a fresh install - This time it all worked fine. The message still comes up but it accepts the file and runs perfectly. Thanks for your help.
Intel DQ965GD
2GB DIMM DDR2-666
Playback engine issue Bill Simmons Getting Started 6 07-01-2013 06:20 AM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
Blackmagic Extreme & playback engine issue goatfish macOS 7 01-14-2013 07:19 PM
Digi001 upgrade to Digi002R doublestakked 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-06-2005 10:28 AM
Can't start Hardware or Playback Engine dialog in PT LE Digi001 fsilano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-01-2001 11:28 AM
