Pro Tools 9.2 Waves Plug Ins
Hey Guys, Im having a bit of trouble here. I have Waves Plug-Ins and for some reason, Its not popping up on my inserts, but popping up under audio suite. I had a windows 7 computer that i got rid of and built a stronger windows 7 computer so i had to reinstall it all. I installed pro tools first then the waves. registered it and now nothings happening. When i open a session it says my old sessions plug ins for waves cant be found and are made inactive. audio suit pulls them up and opens no problem. any suggestions?
Re: Pro Tools 9.2 Waves Plug Ins
nobody knows how to help me? The problem is that it shows up in my audio suite plug ins but not my insert plug ins... help?
Try uninstalling all of the waves stuff again. Once everything is uninstalled delete your prefs and database files for PT.
Reinstall Waves and make certain you are allowing RTAS installation. Read the prompts carefully and follow their directions. Use the full installer (current for your version of waves and bundle/plugs. Should work just fine. Since there are not many people in here complaining of this issue I have to assume that it's local to your rig. The Waves installer is really pretty easy to use and should be working.. (then again, I haven't used the Win installer for some time now). My guess is that your issue will be resolved by clearing your prefs and database files. Also, check your plugin folder to make certain the waveshell file(s) are there. Good luck.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Hold the shift key down the next time you start Pro Tools until you get the Waves prefs pop-up. Make sure "Don't use RTAS" is unchecked.
Thanks Guys!!!! Top Jimmy You Were Right It Was Checked!!! Thanks Guys!!
Pro Tools doesn't recognize Waves Plug-ins | evoplug | macOS | 19 | 06-21-2017 09:11 AM |
Waves Plug-Ins Not Showing up in Pro Tools 11 | protoolsgimp | Pro Tools 11 | 8 | 07-08-2013 08:00 AM |
Pro Tools LE 7.4 & Waves Plug Ins | dsaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-28-2009 11:57 PM |
Waves 6.0.6 and Pro Tools LE 8 - "Select Waves Plug-ins Folder" - Windows XP | toustab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 03-14-2009 01:13 PM |
Importing Waves plug-ins in Pro Tools | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-19-2005 01:24 PM |
