Pro Tools LE 7.4 & Waves Plug Ins
Hello, I'm using Pro Tools LE 7.4 with a Rack 003 now and also Digital Performer with a MotU Interface on the same computer. I installed the Waves Gold Bundle native Plug Ins, because I've bought these for my former DP system. With that it works without any problems.
In the Pro Tools software the plug ins are not identified and do not appear. Now I'm not sure if I should have had Waves Gold Bundle TDM, but isn't Pro Tools LE native? Can anybody tell me if my plug ins have to work on PT or not? Thanx! |
Re: Pro Tools LE 7.4 & Waves Plug Ins
What version are the Waves plugins? My guess is that you don't have the updated version needed to run in Protools 7.4. It is either 5.9 or 6.0 that you need to have. Check with the waves site for the exact specs. If you do have the most up to date version, than it is possible that when you installed waves, you only installed the au versions, because at the time you didn't need rtas (protools), in which case you should be able to just reinstall waves, making sure that rtas, au and vtas are all checked off.
Hope this helps! God bless |
Yeah, I'm with Reb; U need to install Rtas.. That is what PT uses...Not AU as to what DP uses...
Thank you, I'll try and I'll give you response!
Pro Tools doesn't recognize Waves Plug-ins | evoplug | macOS | 19 | 06-21-2017 09:11 AM |
Waves Plug-Ins Not Showing up in Pro Tools 11 | protoolsgimp | Pro Tools 11 | 8 | 07-08-2013 08:00 AM |
Pro Tools 9.2 Waves Plug Ins | batistamusic | Pro Tools 9 | 4 | 09-01-2011 05:51 PM |
Waves 6.0.6 and Pro Tools LE 8 - "Select Waves Plug-ins Folder" - Windows XP | toustab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 03-14-2009 01:13 PM |
Importing Waves plug-ins in Pro Tools | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-19-2005 01:24 PM |
