Old 03-03-2006, 10:38 AM
sminnis sminnis is offline
Default C8 and monitoring through Mbox?
I am trying to set up a configuration with Mbox and the Command8 and am running into an odd problem. When I send the monitor output from the the Mbox straight to my speakers (Tannoy active), everything's fine (sorta, I'm getting a weird crackle, but I'm pretty sure that's a separate problem). However, when I try to run the Mbox line outs into the Command8's monitor ins and then the C8 monitor outs to the speakers, I get nothing. Any ideas where I may be going wrong on this? It's worth pointing out that the C8 seems to be working fine otherwise. All USB and midi-based functions are jim dandy.
Stu
Old 03-04-2006, 12:37 AM
Musick Musick is offline
Default Re: C8 and monitoring through Mbox?
Remember that the Comman|8 has a monitor section with a mute/external source/ and volume..
And your MBox volume still effects the routing going to Command|8...
I am sure is a small step you're missing... no biggy...
Monitoring with MBox 2 Pro 3.14p 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-23-2009 08:04 AM
Monitoring MIdI through Mbox still_life_ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-25-2007 06:26 AM
Monitoring PC Through Mbox 2 dingerkingh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-19-2007 08:19 AM
Monitoring on the Mbox confusedhelp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-04-2006 05:19 PM
Mbox monitoring Niljam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-11-2002 02:16 PM
