Rewire shutdown problems
Anyone successfully using rewired apps like Bidulex64 or Reaperx64 with PT9 on Win7x64, and able to shut down ProTools without it hanging or locking up Windows?
When closing the rewire app first, then ProTools, I get an error everytime and have to kill ProTools.exe in task manager. When attempting to close ProTools first, ProTools will lockup Windows and keyboard access (e.g. no way to call up task manager and kill it). Eventually I got a BSOD and Win7 rebooted. Any solutions to this? Rewire works fine when up and running, but I need a normal, elegant solution to closing projects to make use of it. I may just have to go to VE Pro, though it didn't work within ProTools 8 on my WinXP system. Hopefully I'll have better luck with it under PT9/Win7. Thanks. |
Re: Rewire shutdown problems
I have similar problems when closing after using rewire, though I never found a solution.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I had the same issue with Reaperx64 and PT. Switched to Reaperx32 and all is well.
Right, Reaper 32-bit is the answer for ReWire.
Curious though I don't use many VI's all at once, but I thought the reason you want to use Reaper through rewire is to access more RAM - but isn't a 32-bit app still restricted to accessing 4 GB's? Maybe that 4 plus what PT uses is plenty for VI's - just wondering.
I dropped the rewire idea - VEPro 64 bit server works much better. |
Recording Problems-Crackling on record, Comp Shutdown, CPU usage max. NEED HELP! | Kieran-Joseph | Pro Tools 10 | 13 | 08-01-2013 03:42 AM |
rewire problems | perraultm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-10-2012 03:52 PM |
Please Help! PT7.1 to 7.4 upgrade problems/sudden shutdown | moreese73 | Pro Tools M-Powered (Win) | 1 | 04-22-2008 10:36 PM |
Active USB leads and shutdown problems | derF | Pro Tools TDM Systems (Mac) | 1 | 10-03-2001 05:59 AM |
SHUTDOWN & RESTART problems? | smit1_uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-01-2001 02:53 PM |
