focusrite saff 40. audio clock error. PLEASE HELP
ok, so i have a new focusrite saffire pro 40 and am trying to use it with pro tools 9, but when ever i have it set up and i try to play anything in a session an error pops up saying "detected a problem with audio clock check buffer size" so i go to check the clock source and buffer size in the "saffire mixcontrol" (because it is not contorlled in the hardware title in protools. and every thing matches the session. the buffersizes are 512, its 48 bit and the clock source is internal.
i really do not know what to do next its been a huge struggle PLEASE HELP THANKS a lot windows 7 64 bit, hp dv7 laptop, also the firewire port im using is 4 pin |
Re: focusrite saff 40. audio clock error. PLEASE HELP
With my Liquid Saffire 56 I used to have similar troubles. What worked for me is prior to launch PT open the Mix Control, make the settings that fit your session, leave Mix Control open in the background, then open PT and your session.
BTW, did you choose the Saffire in the Playback engine as your playback device? Other than that I have no idea. I would recommend contacting Focusrite. At least there german support is very responsive. Edit: Did you install the latest drivers from the Focusrite-website? They come with the new version of Mix Control (v. 2.2).
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
yeah i've tryed all that. but thanks for the suggestions. hoping that the new firewire express card i ordered will solve it
"Problem detected with audio clock. Check audio clock and sample rate." Focusrite 2i4 | Terry Wetzel | Third Party Interfaces | 10 | 11-08-2013 06:18 AM |
Audio Clock error ... ? | TDub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-15-2012 01:29 PM |
Audio Clock Error | mongrel8686 | Windows | 9 | 05-07-2012 08:30 PM |
Error: "Problem detected with audio clock. Check that your clock source and sample... | mongo_man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 28 | 05-01-2010 06:08 AM |
::Audio Clock ERROR:: | Zilpex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-03-2005 10:55 AM |
