Automation follows Time compression
Ok...not sure why I'm missing this...but when I consolidate multiple tracks and time compress them, the automation does not follow time compression. It stays in the same place without moving..so now automation is way off.
Where am I missing that option to move automation with time compression? Feel like a newb here.... |
Re: Automation follows Time compression
hey bob! good chatting with you earlier. :)
i've never heard of TCE moving automation points. i just tried it on my v8 setup and it didn't work either. i thought maybe you had to be in Shuffle mode, but that didn't change the result. i made breakpoints in the file, compressed, and the automation would just trim/collapse the automation points and didn't shuffle them. if this is possible i'd definitely love to know how to get it to work! |
Hey Afshar!
I found this response "You might have found a way by now, but I just did a similar thing successfully. I used the Time Compression Expansion plugin to speed up a song. But automation didn't follow. What worked is to change the track time base to tick-based, and then change the tempo." I changed the track time base to tick based an it didn't work. There has to be a way but it's escaping me. Maybe in temp but being a post guy, I'm not familiar with it. |
Volume Automation vs. Compression | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 08-17-2009 11:49 AM |
Automation follows Tempo or Time Compression? | J.D. Andrew | Pro Tools TDM Systems (Mac) | 1 | 01-03-2007 06:17 AM |
Time Compression Expansion | Wicked-Mama | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-05-2003 05:25 AM |
time compression | funkdoctor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-03-2002 02:10 PM |
Time compression | coaster | Pro Tools TDM Systems (Mac) | 4 | 10-22-1999 06:45 PM |
