PT 9 w/ Profire Lightbridge Latency Issues
Running PT 9 MP, on Windows 7 Ultimate, With a Presonus Profire Lightbrige. Having a 4ms delay between headphones, and input monitoring. Sounds like a chorus effect almost, but when you play it back, the recording sounds fine. Worked OK on PT7.4, recently upgraded, and now I have the delay. Thanks. |
Re: PT 9 w/ Profire Lightbridge Latency Issues
There's always going to be a tiny delay, but if you have your buffer set to 64 or less it should be negligent.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
We know what latency is, its not that, when you talk into the mic, it sounds like there is a chorus on in the headphones, almost like there is a feedback between the input and output when monitoring.
Another clue is that when you turn on the cowbell click track, it sounds like wok wok, like theres a phase cancellation going on. |
im not sure how the lightbridge has a seperate DSP monitoring section. the control panel dosent show any mixer like the firewire 410. If i mute the channel in protools there is no way to hear anything. recording in cubase does not have this effect.
your software mixer needs to be set for 'software return 1-2' not 'mixer out' its in the routing section
Issues using PT 9 and Profire Lightbridge S/Pdif | Airton Silva | macOS | 1 | 01-19-2013 03:45 PM |
ProFire Lightbridge / PT10 - Issues Recording | XsuspendedX | macOS | 2 | 12-09-2012 12:32 PM |
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) | tomv-k | Pro Tools M-Powered (Mac) | 5 | 03-09-2012 02:45 PM |
ProFire Lightbridge | mordonic | Pro Tools M-Powered (Win) | 0 | 07-26-2008 05:06 PM |
ProFire Lightbridge - let's get this over with | 3JDamon | Pro Tools M-Powered (Win) | 1 | 11-13-2006 01:52 PM |
