Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-15-2008, 07:14 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default multiple firewire interfaces on same computer.
I'm sure this won't work with M-powered pro tools, but is it possible to use more than one firewire interface on the same computer with other DAW apps? I'm curious if ?I can use my profire lightbridge with a tascam fireone on the same computer - an imac 2.16 C2D with OS 10.4.9 that runs Logic Pro 8.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 06-18-2008, 03:14 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: multiple firewire interfaces on same computer.
it depends on the driver. There are some interfaces, that will work that way, but they must be the same interfaces. Í think that f.e. Edirol has a FW interface, with which you can connect another one to double your I/O´s.
But what I´m sure about is that sequencers can´t have access to different interfaces. Sequencers communicate through the driver with the interface and can only handle one driver for one interface, except the driver is written to have multible instances of an interface...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2019.5
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 06-18-2008, 05:06 PM
GS-DK GS-DK is offline
I use a M-audio 410 for ProTools M-powered and a Fireface 400 for Logic. No problem - Fireface sounds far the best.
Old 06-19-2008, 01:29 AM
clausiii's Avatar
sorry there was a misunderstanding here!
of course you can install dozens of interfaces. An you can use them all! But (in most cases) only one for each application!
My ears! My ears!
clausiii
ProTools 2019.5
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 06-19-2008, 03:54 AM
chris110000100101001 chris110000100101001 is offline
Any sequencer that uses Core Audio can use an Aggregate Audio Device
SMPTE for the devil
Multiple FireWire interfaces PT 9 OSX. FIRESTUDIO AND SAPPHIRE 40 Invisible Pro Tools 9 2 08-16-2011 10:13 AM
Multiple interfaces to PT9 towelhead macOS 3 05-26-2011 10:18 AM
multiple firewire interfaces in PT9LE mzkguy Tips & Tricks 1 04-05-2011 02:22 PM
multiple M-Audio (and DigiDesign) interfaces on the same computer marcnyc Pro Tools M-Powered (Mac) 5 09-02-2008 07:50 PM
Multiple Interfaces? obligato Pro Tools M-Powered (Mac) 0 02-07-2007 08:24 AM
