Old 08-31-2010, 11:22 PM
michaelm michaelm is offline
Default retaining region colors when copying
when I copy (or move) segments from one track to another for editing/assembling - is there a function somewhere (and what is it called) that keeps the region color the same instead of assuming the color of the track it's been moved to?
Pro Tools 8.03, Fujitsu-Siemens AMILO Xi3650 laptop, 18.4 in. HD display, Intel Centrino2 Duo CPU P7350 @ 2.00GHz, NVIDIA GeForce 9600M GT graphics, Realtek High Definition Audio, 4GB RAM, Vista HP (32-bit), Digidesign Mbox 2 Micro
Old 09-01-2010, 12:00 AM
mano111 mano111 is offline
Default Re: retaining region colors when copying
open the color palette window.
select the desired regions
make sure the color palette window's drop down menu is on region and select the desired color.
Its also possible to change the default region color in preferences > Display> Default Region Color Coding , though I don't know if any of the options provided will be what you want.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 09-01-2010, 12:12 AM
yes, of course I can change it afterwards - cumbersome, though, if you have lots of bits you're moving around
however .... I played around with Preferences > Display> Default Region Color Coding - Track Color doesn't do what I want - BUT Region List Color DOES!
if you set the color for the regions in the original tracks, then they stay the same if moved or copied to other tracks
voila!
Old 09-01-2010, 12:24 AM
Cool
region colors in playlist swv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-31-2012 12:29 PM
Problem with Region Colors Carl Lie macOS 1 05-25-2011 03:12 PM
Region Colors Mike Greene Pro Tools TDM Systems (Mac) 3 08-17-2010 03:37 PM
Region Colors are all grey... Extreme Mixing Pro Tools TDM Systems (Mac) 2 09-09-2009 02:17 PM
First note in region is lost after copying/duplicating region chrisdee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 04-22-2009 04:46 AM
