Old 03-12-2010, 01:11 PM
michaelm michaelm is offline
Default exporting click track
I am exporting audio tracks as .WAV files (to be used for overdubs at a studio that uses Logic Pro)
I also need to have the click track (created with the click plug-in) with that - how can I export this? I assume that I somehow have to create an audio track of it - but how? don't seem to be able to figure this out.
any (detailed?) help?
thanks
Pro Tools 8.03, Fujitsu-Siemens AMILO Xi3650 laptop, 18.4 in. HD display, Intel Centrino2 Duo CPU P7350 @ 2.00GHz, NVIDIA GeForce 9600M GT graphics, Realtek High Definition Audio, 4GB RAM, Vista HP (32-bit), Digidesign Mbox 2 Micro
Old 03-12-2010, 01:52 PM
DGraham DGraham is offline
Location: Jacksonville, Florida/Rotterdam, The Netherlands
Default Re: exporting click track
Just buss the click track output to an audio track, record it, then export it as a .wav as you would anything else.
Win7 64 Ultimate - Intel Core i7-920 Bloomfield 2.66GHz - Gigabyte EX58-UD3R - OCZ Gold 6GB - Radeon X550 256MB Video Card - 750GB Caviar Black System, 500GB Hitachi SATA Sample, and 750GB Caviar Black Audio - 500GB Caviar Blue Backup - Pro Tools 8.0.4 LE - Signature Series Digi 002R
Old 03-12-2010, 01:57 PM
Wango Wango is offline
I've done this by recording the click track to an audio track.
1) Create a new audio track, name it something like 'ClickTrack'
2) Set the output of the click track to this audio track
3) Set transport to beginning of song
4) Record to the end
Then, you can use the wav (or aif) file for the click track region from the session/audio files folder.
There might be an easier way, I've meant to ask this myself.
Wango
Don’t piss down my back and tell me it’s raining.
http://www.soundclick.com/bands/defa...?bandID=851389
Old 03-12-2010, 03:02 PM
TOM@METRO's Avatar
^^^Yup, as said above. ^^^
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-12-2010, 03:26 PM
thanks - yes, that works of course
both answers seem to be the same
sooo ....... IS there an(other) easier way? anybody?
Old 03-12-2010, 06:25 PM
If there is no easier method, I could see this as a useful, albeit low priority enhancment.
Either:
1) When you do a bounce, have an option for exporting a click track
In this case, another file is generated with the bounce, e.g.
MySongClick.aif
OR
2) Have an option like 'File/generate click track file'
This would allow you to browse for where to place the file.
Certainly not a high priority feature, but a nice to have.
Working with click tracks is so common.
Wango
Old 03-14-2010, 03:24 AM
absolutely! this is such a common studio technique that it really should have a simple plug-in
another (probably very basic though ... sorry) question:
I use Create Click Track from the Track menu
the INSERT shows Click
I choose a SEND - Bus 7 (mono)
I create a mono Audio Track
on the I/O audio input path I select Bus 7
and Out 1-2
if I now play the click I can not see any input (nor hear it) at the Audio track (also not if I record enable it)
If I then actually record on the Audio Track, then I can see it coming in and recording the click (and I can then also hear it when playing back)
why can't I hear it without recording it? what am I missing here?
P.S.: could it have anything to do with the fact that I am using an Mbox 2 Micro? (which doesn't have any recording input facility)
Old 03-14-2010, 04:39 AM
It's probably because you're using input only monitoring.
It's the same deal as if you record any other input.
I always have my system set this way, so I don't recall offhand where to change it.
With anything I record, I don't hear the input while it's playing, only when it's stopped or recording.
Wango
Old 03-14-2010, 08:23 AM
yes, thanks, that was it
you change it for record-enabled tracks from the Track menu to auto input monitoring or by toggling it with Alt-K (it's in the manual on p. 364 ... of course one needs to first know what to look for ...)
Avid can you please sort out the click track & Click 2 plugin protoolsuserman Pro Tools 11 14 11-14-2013 08:11 AM
Exporting Click in Non Real Time dabhoys Tips & Tricks 3 12-16-2008 11:28 AM
Getting the click track to click at 16th notes... broken81 Tips & Tricks 1 06-27-2008 07:06 PM
Click Track - How to "UN" accent the click plugin pepperbox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-02-2006 06:37 AM
Exporting 1 track Chorus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-09-2004 08:25 PM
