what motherboard should i get 4 digi 001?
i know i'm way behind with my hardware, but it's all i can afford for now. plus i'm just tracking beats anyway. a friend of mine gave me a computer from his job and it has windows nt on it, but i want to install windows xp on it. the motherboard that's in it is:
Model Brand: PC CHIPS Mode:l P21G (V3.1) Supported CPU CPU Socket Type: LGA 775 CPU Type: Pentium 4 Prescott / Celeron D FSB: 800/533MHz Chipsets North Bridge: VIA P4M800 South Bridge: VIA VT8237 Memory Number of Memory Slots: 2×184pin Memory Standard: DDR 400 Maximum Memory Supported: 2GB Expansion Slots AGP Slots: 1 x AGP 4X / 8X PCI Slots: 3 Other Slots: 1 x CNR Storage Devices PATA: 2 x ATA100 4 Dev. Max SATA 1.5 Gb/s: 2 Onboard Video Onboard Video Chipset: S3 Graphics UniChrome 2D/3D Onboard Audio Audio Chipset: Realtek ALC655 Audio Channels: 6 Channels Onboard LAN LAN Chipset: VIA VT6103 Max LAN Speed: 10/100Mbps Rear Panel Ports PS/2: 2 COM: 1 LPT: 1 Video Ports: D-Sub USB: 4 x USB 2.0 Audio Ports: 3 Ports Onboard USB Onboard USB: 4 x USB 2.0 Physical Spec Form Factor: Micro ATX Dimensions: 9.6" x 9.6" Power Pin: 20 Pin Packaging Package Contents P21G (V3.1): User Manual Driver Disk Rear I/O Panel Shield IDE/PATA Cable FDD Cable SATA Cable Power Cable i just wanted to know what type of motherboard should i purchase, like processors those type of things. thanks |
Re: what motherboard should i get 4 digi 001?
I had a socket 754 AMD socket 754 board running the KM800 chipset with the 8237R south bridge and it ran PT just fine.
I would update that to XP. Install 2 GB of DDR400 and drop in something like a E 2180 Pentium Dual Core CPU (if it will run one). You will also need a AGP video card and a internal HDD for your audio. Check the motherboards manufacturers site to see what types of modern CPUs you can install into it. If you can install a more modern dual core processor I would maybe add the memory and video card. If your stuck with a single core Pentium 4 I would not put any money into it at all.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
thanks for your help.
Motherboard DIGI 001 | mbkorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-29-2011 04:44 AM |
New motherboard for Digi 001 | DorianMode001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-31-2005 02:27 PM |
Digi 001 and SiS Motherboard? | bloodspoint | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-26-2003 12:13 AM |
WHAT MOTHERBOARD IS THE BEST FOR DIGI 001????? | JINGLES STUDIO COLOMBIA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-31-2002 12:04 AM |
BEST MOTHERBOARD FOR DIGI 001 | OHENEBA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-08-2002 11:34 AM |
