Old 04-03-2007, 12:37 PM
Vank Vank is offline
Default Suspend Midi track Control data question
Hi all,
How do I keep midi tracks in HD 7.3.1cs2 from sending midi volume/pan etc to the instrument they are assigned to?
Many thanks for an answer as this is driving me crazy because touching a midi fader alters the parameter in kontakt...
Cheers!
Old 04-03-2007, 12:57 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Suspend Midi track Control data question
Hi all,
Cheers!
Select the function that you want to suspend on the track, volume, pam, mute etc then command+control+click on it to disable it.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 04-03-2007, 02:04 PM
Hi Chris,
Thanks for the answer, unfortunately I can't get it to work, could you elaborate a bit more maybe.
Where exactly do I suspend the chosen parameter...I have track automation in off mode already but it still sends the controller data from the fader, fyi there is no controller data in the track at all.
Cheers!
Old 04-03-2007, 06:02 PM
crizdee's Avatar
Hi Chris,
Cheers!
Your track view selector? where you select to view waveform/volume/pan/mute etc, immediately above your midi patch selector!!
Select pan now hold down these modifiers... Command (apple) plus the Control key and at the same time click on the word pan . it should now turn to a faint grey! disabled.
NOW here's the bizarre thing Digi?? save and reload the session and its back activated!! so it has to be done each time you load a session!!!
Turning automation to off will suspend all automation for the track!
Yes, i've had this problem as well with multi-channel plugins and samplers!
Chris
Producer, Engineer,
www.ukmastering.com
Is there a way to control midi data with my voice? jaytonbye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-26-2011 12:13 PM
copying Pan Data from midi track to audio track calmborncreator MIDI 2 07-21-2009 12:51 AM
Can I use Midi data on one track through multiple instruments kfoody Virtual Instruments 1 07-14-2009 02:56 PM
removing all midi control data except... cc1 Pro Tools TDM Systems (Mac) 1 06-12-2005 05:32 PM
MIDI STOPS TRANSMITTING TRACK DATA crizdee Pro Tools TDM Systems (Mac) 1 03-09-2005 08:23 AM
