Hardware Latency Compensation with MTRX
Hey all
We are thinking of switching to either an MTRX or MTRX Studio and there is a couple things I've been having trouble finding an answer to in documentation. I reached out to Avid sales and the person I spoke with couldn't give me an answer. If anyone with experience has time to let me know that would be greatly appreciated! 1. When connecting to the MTRX as a Dante interface through a PCIE Dante card, (for use with another DAW outside of Pro Tools) Are ALL inputs and outputs of the MTRX available to the Dante network? Or are some channels only accessible via HDX? 2. When using the MTRX through an HDX card how is latency/delay compensation handled for additional IO coming in through ADAT/Dante or Madi? As an example say you were using an I/O Insert in Pro Tools to connect to a hardware compressor, which was sending and receiving on channels allocated to a Madi or Dante device. Does the MTRX track this additional latency and relay it to Pro Tools? would Pro Tools compensate that delay properly? Or would you need to manually enter the hardware delay for any channels being converted outside of the MTRX box itself? thanks! |
Re: Hardware Latency Compensation with MTRX
Greetings,
Yes, all populated Dante options and built-in (MTRX ST) are accessible to the Dante network. No, Pro Tools doesn't have a trail of breadcrumbs to know what formats you traversed before coming in and out of Pro Tools so these compensations would have to be manually entered. best, Jeff |
DADman in the MTRX units is a patching matrix. If you are using the 64 i/o onboard Dante, you can send those 64 (and received) from any other input/output on the system. Same true for the 128 channel addon card on the full size MTRX. It's up to you how you want to assign that routing but none of the other inputs/outputs are limited from your choices. Quote:
One of these days, we'll be able enter delays in samples in Pro Tools and finally sample rate of a session won't matter. (I still find entering msecs kind of dumb for a DAW)
Ah ok thanks for the reply's!
Yes hopefully soon there is also a way to ping the inputs/output and calculate the delay time automatically. (ala Logic, Reaper, Studio One) One more question for clarification: For example with the MTRX Studio, if 1-16 in and out on the HDX are routed to 1-16 d-sub in and outs built into the MTRX Studio, that latency must be compensated manually in the hardware delay tab as well? |
MTRX Studio AD->DA has additional hardware insert delay. |
Yes, we've discussed the possibility of creating an integrated ping tool which would be beneficial for these types of scenarios. I've also suggested that we use samples instead of ms with regard to the IO Setup Hardware Insert Delay fields.
best, Jeff |
Did this progress further than just a discussion? A Ping tool would be a VERY welcome addition and yes, definitely should be samples not milliseconds. Sent from my iPhone using Tapatalk |
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Until the last major release complete with its new VIs and music focused marketing, we were beginning to believe Avid simply was giving up on music production and only focusing on post. Avid should recognize that those who are signing up for their low cost subscriptions still may want to use outboard gear, sometimes with external converters, and forcing them to either set delays manually or only buy Avid gear would be a strategic miss step.
>Mac Studio Ultra, MacOS Monterrey >Avid MTRX >128 Ch Dante Expansion Card >HDX Expander Expansion Card >1x Opt Madi Expansion Module >2x Madi Expansion Cards >96ch of 96k SSL Alpa-Link AD/DA (4x 24ch, Madi) >4x Rupert Neve Designs 8-Ch RMP-D8 Pres >6x Rupert Neve Designs 5057 Summing Mixers >Protools Flex Sub/Ultimate/2HDX (Always updated!) >3x S1 + Dock >We use our Protools rig for livestreaming every weekend and production of our own music Last edited by jiminyxmas12; 07-03-2022 at 02:47 PM. |
HDX + MTRX Core Audio Latency in Logic? | basehead617 | Pro Tools | MTRX & MTRX Studio | 2 | 02-02-2023 10:09 AM |
Delay compensation between MTRX an Avid I/O | Ashford | Pro Tools | MTRX & MTRX Studio | 3 | 06-06-2022 01:06 AM |
Hardware Latency/Delay Compensation | grg1540 | Avid Pro Mixing General Discussion | 11 | 10-03-2018 10:19 AM |
MTRX Dante latency stuck at 1ms | LukeHoward | Pro Tools | MTRX & MTRX Studio | 1 | 02-19-2018 11:13 PM |
Latency Compensation on Hardware Inserts | BJosephs | macOS | 6 | 07-11-2011 06:45 AM |
