Upgrade my Mac Pro Mid 2010 for HDX
Hi guys
It'good for you to upgrade my Mac Pro Mid 2010 Nehalem Quad Core 2,8GHz with a 2010 Processor Tray 6 Core 3.33Ghz W3680 / 32GB 1333Mhz RAM?? I have HD 2 Installed on my Mac, but I want to exchange with new HDX & PT HD 12.5 It's a good investment on my machine? Thanks a lot!
Mac Pro (Mid 2010) Six Core 3.33GHz macOS 10.14.6 MSI Radeon RX 560 Pro Tools | HDX, HD I/O 16x16, HD I/O 8x8x8 Pro Tools Ultimate 2022.9 MacBook Pro (Mid 2012) i7 2.3GHz macOS 10.15.7 Pro Tools 2021.12 Apogee Duet |
Re: Upgrade my Mac Pro Mid 2010 for HDX
I would not upgrade a single-cpu to a faster one, especially if you have HD and likely use a lot of TDM plugins
OK, but I really don't use a lot of TDM plugin.. and I want to exchange my HD2 with HDX... So can I install HD 12.5 on my Quad Core machine?
Yes. But why?
Your 8.1.1 is as stable as it can be, you need to have a real reason for the upgrade. Say, you need Cloud Collaboration, your new plugin purchases require newer operating system than Snow Leopard, your some other software XYZ doesn't run on your current machine... Obviously crossgrading from TDM to HDX is a real reason, but if you don't use much DSP now, why on earth would you change to another type of DSP? HD2 can support 64 i/o so in that regard you would be fine with HDN
Including the HDX Card??
And do you think is more powerful the Xeon Quad 2,8Ghz ore the i7 Quad 2,3Ghz?? I have open some session from my HD2 on my MBP w 12.5 and the i7 work great! Thanks a lot!
But with that said, the laptop will run hot if you stress it, and therefore the fans make a lot of noise and you won't be able to put it under your desk.
I would at least start with the current computer and see if there's going to be performance problems. If so, then do something about it. If not, be happy
OK, thank you!
Pro tools express crashing following upgrade to windows 2010 | chanchan82 | Windows | 4 | 03-27-2016 04:12 AM |
PT 11 on mid-2010 Mac Mini | oakenhead | macOS | 0 | 03-03-2014 06:53 AM |
2010 Mac Pro Compatibility? DTS??? | Marsdy | Pro Tools TDM Systems (Mac) | 0 | 09-27-2010 03:02 AM |
musikmesse 2010 | brothermunk | Pro Tools M-Powered (Mac) | 0 | 03-19-2010 06:21 PM |
NAB April 2010 - anything new ?? | scotsman | Pro Tools TDM Systems (Mac) | 16 | 03-09-2010 11:40 PM |
