Old 03-26-2020, 12:40 PM
dcoffset dcoffset is offline
Default Re: MIDI Record works but not Retrospective MIDI Record or MIDI Loop Record
Originally Posted by Evermore View Post
From what I can tell, this is similar to a bug I recently reported and it was marked and logged as a known bug/defect.
The problem is actually "Midi Merge". When Loop Record is turned on, Midi Merge automatically turns off causing this issue.
Try this: Put record on normal and then turn Midi Merge off. Start recording or use Retro, you will get the same result.... no midi. Now, grab the empty midi clip and extend the end out around 10 bars. The midi notes you recorded will appear far ahead by a few bars.
The only workaround is not to use Loop Record for the moment.
I can confirm that is what happens... when i drag out the take i eventually find the midi data (in my case this was more than 10 bars). A far as i'm concerned that's not a workaround, its broken and defeats the only way to emulate an audio playlist workflow. When did you report it?
Old 03-26-2020, 02:34 PM
sandberg sandberg is offline
I´m having the same issue since 3 days ago, just out of the blue. It seems like retrospective record works, but is somehow delayed relative to the starting point of the session. If I play some midi at 1 minute and 30 seconds and hit Retrospective Record, the midi file will appear to be blank until I drag it out till it shows all the notes I played. Then I move the file back 1 min 30 sec, and it will be where I originally played the part. If I play something at 3 minutes 43 secs, I´ll have to do the same and move it back 3 min 43 secs. If I start at the exact beginning of the session, it´s in sync. Sure hope there will be a fix for this very soon
Old 03-26-2020, 04:40 PM
Evermore Evermore is offline
I reported it less than a week ago and was confirmed and logged, meaning a fix will come soon.
Yes, a shame Loop Record is not working correctly as I too use it quite a lot.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Apogee Symphony IO mkii
Old 05-23-2020, 03:45 PM
drh1's Avatar
drh1 drh1 is offline
I just wasted a few hours trying various ways to do loop recording on an instrument track using PT 2019.12 in Windows 10. I experimented with every configuration I could think of but similar to dcoffset I found that loop recording would only work if starting from the first bar. Obviously, not helpful at all. I just discovered this thread and was hoping someone may have found a solution over the past two months.
http://douglashood.zenfolio.com/
MSI X99A SLI Plus LGA2011, i7 5930 3.5 GHZ 6 core 12 threads, Kingston HyperX Fury 64GB DDR4 2400MHZ, NVIDIA Quadro K2200, LG 16x Blu-ray writer, Samsung 850 Pro 512 GB SSD for OS, Samsung 970 EVO Plus NVMe M.2 1 TB SSD for samples, four WD Caviar Black 1TB SATA 3 6Gb/s 7,200 RPM drives (audio, samples, video x 2), EVGA Supernova 750W G2 PSU, Corsair Cooling Hydro H100I V2, W 10 Pro, 4 TB WD USB3 external backup, PT 2020.5, IK Sampletank 4 Max, AIR IEP, Wavelab Pro 10, RME Fireface UFX w USB2 connection.
Old 05-23-2020, 04:42 PM
cantfindabed cantfindabed is offline
Can you not update to PT 2020? The bug is supposedly fixed there
  #16
Old 05-23-2020, 05:05 PM
drh1's Avatar
I just checked the Read Me document for Pro Tools 2020.3 and it does appear that this may be addressed with that release. I will update tomorrow (although the latest version is now 2020.5 in my Avid Account. Thanks.
  #17
Old 05-31-2020, 02:22 PM
drh1's Avatar
I installed PT 2020.5 and so far the midi loop recording seems to be working as it should.
Retrospective MIDI record not working uwmsc Pro Tools 12 22 05-24-2018 09:03 PM
Loop Midi Record greenglassdrum Pro Tools 10 2 11-26-2011 11:48 AM
Pro Tools 8 MIDI feature : "Retrospective Record" and arpeggios ? original General Discussion 2 10-07-2008 12:57 PM
midi loop record vstamos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-04-2007 12:56 AM
midi loop record? Keith Moore Pro Tools TDM Systems (Mac) 2 06-14-2006 09:18 PM
