Constant Crashing with PT 9.0.0
I'm experiencing nearly constant crashes. (See my profile for the computer setup.) I'm running into a Black Lion Audio modified 002R.
I have fully uninstalled (clean) and re-installed ProTools seven times now, and the problem continues. Now, when I try to instantiate a send, it crashes. This, however, is not the only time it crashes. It seems capricious...it'll crash for any reason (notably, when a client is present.) Oddly, there are no labels on any of my plugins. I've tried holding down the shift key to launch without plugins, but the plugins still launch(???) Does anyone have any clues as to why this is happening, and what I can do to fix it? _____________ Brent Walker Mac Pro Dual Core 2.66gHz 4 gigs memory OS 10.6.5 Last edited by lbwalker; 01-11-2011 at 02:34 PM. Reason: profile didn't show up. |
Re: Constant Crashing with PT 9.0.0
Make absolutely sure all of your plugins and/or rewire apps (like reason/record) are up to date.
Then... check again. Incompatible plugins are easily the most common reason for instability.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Since the shift key when starting function is not working to prevent your plugins from loading, try dragging all your plugins into the unused plugins folder and restart. Check to see if PT still crashes. If not, start to drag the plugins back one at a time and restart PT and check for stability before repeating for the next plugin. It is a tedious process but a reasonable way to troubleshoot your problem it it is plugin related.
I always remind people to record to a approved physically separate drive and to set their playback engine to one processor core less that they actually have to ensure non-realtime plugins have a processor to use. FWIW: My PT 9.0.1 system is running very smoothly so I think it is possible.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Also, since you say that your plugs have no labels it sounds like you have a font issue described in any number of threads going right now.. do a search to learn how to resolve that.. it may just clear up your other issues as well..
For me, 9.0 on a 8 core running 10.6.5 flawlessly. PT has never worked so well for me..
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Just to clarify!! you need to hold down shift key when you open the "session" (not when launching pt) this has always worked so would be surprised if its not working for you. Your plugins have no labels??? do you mean in the plugin folder they are not showing their version numbers? if so you right click in the folder and set version in the view options. Important that you use the combo updater for apple OS updates, so try running the 10.6.5 combo updater! Plugins are the major cause of all issues!!!! did you install over a previous version of pro tools? you need to check ALL third party plugins are up to date and remove any old demos or out of date plugs from the plugs folder!!! you must also trash prefs to empty the plugins cache!!!!!!!! Uninstalling PT does not remove optional and third party plugins they have to be removed manually then trash prefs to empty cache Chris
Go to FontBook and check your fonts. You may have some system fonts missing.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Constant System Crashing | nailay7 | Windows | 7 | 02-17-2014 12:07 PM |
Constant Crashing | sammikins | Pro Tools 10 | 6 | 07-01-2013 07:12 PM |
Constant crashing / kernel panics HD2/G5 | skeeters | Pro Tools TDM Systems (Mac) | 1 | 12-17-2011 10:58 PM |
Constant crashing since 7.x | getfunkymp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-01-2006 09:43 AM |
Constant Crashing on ox.2.8 and digi001 | Locash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-19-2003 10:24 PM |
