Old 04-07-2021, 05:03 PM
mophilly mophilly is offline
Default Save Copy in and unexpected project path
MacOS 10.15.7
PT 2021.3
I used Save Copy In to create a new project in a folder I created for it. The new project folder contained a ptx file, a folder named Fade Presets, and a folder name MacHD.
The folder MacHD surprised me as it contained a set of nested folder that mirror the full path name to the project folder that contains the expected elements, like "Audio Files", etc.. The folder nesting is MacHD/Users/,username>/Documents/Pro Tools/<source project name>/<new project name>/
Did I miss something here?
Old 04-08-2021, 07:31 AM
Default Re: Save Copy in and unexpected project path
Did you click the checkbox to include the audio files? If you missed that, the copy session will refer to the original source of the audio files
Old 04-08-2021, 07:43 AM
Thank you for the reply.
Yes, I did check that box. To double check I will compare the two directories (source and new). I *assume* the audio files folder content will be the same.
Old 04-08-2021, 04:00 PM
I check the two directory trees. The content of Audio Files is the same, differing only in last modified date. There some differences in some of the other project directories.
Now, my question is about the deep path. I expected a shorter one. The original project looks like this:
Code:
<user>/Documents/Pro Tools/Projects/<project name>/
The one created by Save Copy In created this:
Code:
<user>/Documents/Pro Tools/Projects/<new project name>/MacHD/Users/,username>/Documents/Pro Tools/<source project name>/<new project name>/
I am concerned I goofed up somehow.
Old 04-08-2021, 04:37 PM
Hmmm, I don't think you goofed, but I do think you may want to re-think your file strategy. Is your main hard drive an SSD? If it IS, then maybe all is fine(though it rubs me the wrong way). I prefer to keep all my sessions on a separate hard drive from the OS. Some of this is due to old habits(in the days gone by(with spinning hard drives), Pro Tools systems always recorded to a separate drive(or two) for performance. These days, a good SSD can allow you to have everything on a single drive, BUT, do you really want that? Of course, if your main drive is a spinner, then you absolutely want to have your sessions on a separate drive, for performance
While you think about how to answer that, creating full copies of sessions is a wise thing to do(actually....TWO copies) and these copies should be saved to separate hard drives(regardless of drive type). The idea is to have any session you don't want to lose, exist in at least 3 places(separate drives, certainly. And 1 of those drives should be stored in another building, in case of fire)
I know PT defaults to this location in Preferences, but I always(as in ALWAYS) change that setting to prompt for me to choose where sessions go(and for me, that place is a separate drive).
Old 04-09-2021, 08:18 AM
I don't suppose you've got some cloud-based backup going? Perhaps iCloud "Desktop and Documents Folders" is turned on? Some other Dropbox sync thing going on? If so, turn them off, or record your projects on an external drive.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
1) "Save Copy In" command does NOT make a complete copy! 2) How to properly backup XNA Pro Tools 2018 18 05-28-2019 03:52 PM
Save Session Copy doesn't copy all files within the bin anymore Farhoof Pro Tools 12 13 11-27-2015 09:11 AM
SAVE COPY IN bounce file nor .mov copy saved ronjohn333 Pro Tools 11 1 10-01-2015 12:46 AM
"Save Session Copy in" occasionally doesn't copy.. Willard Pro Tools TDM Systems (Mac) 0 03-06-2007 12:31 AM
save sesssion copy x copy folder to another HD Alécio Costa Pro Tools TDM Systems (Mac) 6 10-22-2002 09:29 AM
