#31
Re: Any MB with 1155 socket that can support original PCI HD cards?
Got my board from Norway, Power supply is a brand new Corsair tx750
#32
Power supply is ATX v2.3 compliant and is backwards compatible with 2.2 and 2.01. The motherboard manual says it need ATX v2.0 power supply. Is this my problem?
#33
An an update, I've added an Accel card so I'm now running HD|3 (Core/Accel/Process) on the Jetway board. Through a couple of tracking sessions, so far it has performed just fine.
Joshua L. Decatur, AL |
#34
Mr Joshua - what power supply did you use for your build?
#35
It's an Antec Basiq, I think 550W. Nothing huge. I'm using the onboard video, two internal hard drives plus an SSD ... nothing that requires an enormous power supply.
#36
Well I got my JETWAY Build working.
JETWAY NAF92-Q67 Intel i7 2600K processor Corsair GS700 Power Supply (TX750 V2 Enthusiast didn't work!!!) 16GB Corsair XMS3 Dual Channel DDR3 - though i have a problem with this as only 8GB is showing - I did have all 16 at thestart when i was installing windows - not sure what is happening there Corsair Force 3 SSD 120Gb for my system drive - SATA3 Western Digital 1TB Caviar Black as my audio drive - SATA3 SAMSUNG HD6422JJ 500GB drive for loops and VIs ATI Radeon 4350 Display Adapter (dual DVI outputs to run 2 monitors) HD2 Accel running Protool 9.0.5 on Windows 7 Pro 64-bit So the memory thing is an issue, also can't install some of the software that came with the mb - the Intel management Engine says the computer isn't up to spec, though me is enabled in the bios? Grateful if anyone has any ideas re the memory, I've reset the CMOS but it didn't make any difference.... Got the memory back, I changed the sata mode to AHCI which gave me a blue screen death... suffered the system repair wizard, went back into the bios to set sata mode back to ide, and now it can see all 16Gb.... tis a mystery. Last edited by lennieh; 10-21-2011 at 06:13 PM. Reason: addendum |
#37
memory is gone again. Sandra report is weird, it shows slots 1 and 3 empty same as the bios but reports info for all 4 sticks......
i'm stuck now... |
#38
sandra
SiSoftware Sandra Computer Workgroup : WORKGROUP Host Name : Guinevere User : Lennie Processor Model : Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Speed : 3.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer BIOS : AMI (OEM) 4.6.4 06/29/2011 Bus(es) : X-Bus PCI PCIe USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 8GB DIMM DDR3 Chipset Model : Intel Core (Sandy Bridge) DRAM Controller Front Side Bus Speed : 100MHz Total Memory : 8GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 667MHz (1.33GHz) Memory Module(s) Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Video System Video Adapter : ATI Radeon HD 4300/4500 Series (40 SM4.1 600MHz, 1GB DDR3 800MHz 64-bit, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4300/4500 Series (40 SM4.1 600MHz, 1GB DDR3 800MHz 64-bit, PCIe 2.00 x16) Graphics Processor OpenCL Processor : ATI Radeon HD 4300/4500 Series (40SP 2C 600MHz, 512MB DDR3 800MHz 64-bit) STREAM Processor : ATI Radeon HD 4300/4500 Series (40SP 2C 600MHz, 1GB DDR3 800MHz 64-bit) Storage Devices WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (E:) (H:) (I:) SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 596GB (F:) (K:) Corsair Force 3 SSD 120GB (SATA600, SSD) : 112GB (C:) SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 596GB (G:) (J:) Disk 2GB (USB) : 2GB (L:) TSSTcorp CDDVDW SH-222AB (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices Audio (E:) : 639GB (NTFS) @ WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm) Loops (F:) : 547GB (NTFS) @ SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) System Reserved : 100MB (NTFS) System (G:) : 153GB (NTFS) @ SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Removable Drive (L:) : 2GB (FAT) @ Disk 2GB (USB) Jacky Audio (H:) : 195GB (NTFS) @ WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm) Misc (I:) : 98GB (NTFS) @ WDC WD1002FAEX-00Y9A0 (1TB, SATA600, 3.5", 7200rpm) Software (K:) : 49GB (NTFS) @ SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) System (C:) : 112GB (NTFS) @ Corsair Force 3 SSD 120GB (SATA600, SSD) Downloads (J:) : 146GB (NTFS) @ SAMSUNG HD642JJ (640.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Optical Drive (D:) : N/A @ TSSTcorp CDDVDW SH-222AB (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Intel Cougar Point LPC Controller LPC Legacy Controller 1 : T0 10-07 Audio Device : PC Partner R700 Audio Device [Radeon HD 4000 Series] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : Intel Cougar Point 4 port SATA IDE Controller Disk Controller : Intel Cougar Point 2 port SATA IDE Controller USB Controller 1 : Intel Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Intel Cougar Point USB Enhanced Host Controller #1 FireWire/1394 Controller 1 : TI XIO2213A PCI Express to 1394b OHCI with 3-Port PHY SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : (2GB) Network Services Network Adapter : Intel(R) 82574L Gigabit Network Connection (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 3.5 |
#39
Any Intel Q67 based board will give you native pci bandwidth.
I am using one right now for my dual pci card Pyramix Masscore which is as taxing on the pci bus as you can get. |
#40
sounds like bad ram. go buy another set and swap and see.
ProTools 2018 1 x Apollo Quad Firewire 1 x Apogee Duet 2 mac/ios MacBook Pro (15-inch,2018) 2.9 Ghz Intel Core i9 CPU 32 GB 2400 DDR4 RAM 1TB SSD System Drive Mac OS High Sierra 10.13.6 |
Anyone Having Success With 1155 Socket? | johnjm22 | Windows | 8 | 12-08-2012 03:37 PM |
what chipset works with 1155 socket? | raytravel | Windows | 16 | 09-07-2012 05:52 AM |
Original HD cards, what mac?! | PTPerson | Pro Tools TDM Systems (Mac) | 4 | 03-07-2012 12:04 PM |
Modern motherboard for original PCI HD Core and Process cards | David Sandwisch | Pro Tools TDM Systems (Win) | 48 | 08-28-2011 02:19 PM |
Firewire Cards for 002 - With AMD 64 x2 - AM2 Socket - ERROR *DELETED* | Table Syrup Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-18-2007 09:52 AM |
