Old 01-18-2020, 10:15 AM
moogboy100 moogboy100 is online now
Default Control App Monitoring Dim Button Label Gone
Ever since the major new update to the Avid Control app a few months ago, the Dim button has broken in the Monitoring section.
The Cut button is still there, and works. And the Dim button is above it and still works - it just no longer labeled "Dim"...it's blank.
This is the Control app on iPad with a Dock and the latest Eucontrol software and PT Ultimate.
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.3
Old 01-18-2020, 12:07 PM
BScout BScout is offline
Default Re: Control App Monitoring Dim Button Label Gone
What monitoring hardware are you controlling? For instance, for the MTRX with DADman, if the Ref light is switched on in DADman, the volume control isn’t sent via Eucon so the main volume remains blank on the Avid Control app. The minute you turn ofF Ref, the “knob” info transfers and the Control app shows a volume knob and can be adjusted.
So what you are controlling has to update the Control app for what it is/has.
Old 01-18-2020, 12:44 PM
None. Just assigning a master fader to the Dock's master knob.
In that scenario, all you get it the Dim and Cut buttons.
But like I said, the Dim still works, just no longer labelled in the app.
Instrument Track - No Input Monitoring Button - Why ? Seafoam_Green Pro Tools 12 14 03-06-2022 05:09 AM
Input monitoring button in Dock Maro Records Avid S1, S3, Dock and Control App 9 04-08-2018 12:11 PM
S5MC: Inserting "PAUSE" in command string overwrites button label NAEP_Matt System 5 1 10-20-2016 05:15 PM
Software monitoring button ? PMcC macOS 1 08-01-2012 07:18 AM
Audio input monitoring button on C24 tamtamstudio ICON & C|24 0 11-23-2004 06:12 AM
