Old 03-25-2010, 10:43 AM
amac84 amac84 is offline
Default vocal distortion problem
Hi, I'm currently working on a short film and received the on set recording of the dialogue and there is a scene when the character screams and the sound mixer on set didn't adjust for the scream and the audio peaks and distorts.
Is there any plugin I can use to clean it up?
Any help would be greatly appreciated. Thanks!
Old 03-25-2010, 12:02 PM
Top Jimmy's Avatar
Default Re: vocal distortion problem
You could try the BF Essential Clip Remover audiosuite plugin. Understand though that it only works if the clipping is at -0 dBFS. If the gain was reduced after the clipping, you'll need to take it back to -0 otherwise the Clip Remover won't do anything.
For pay, there's Izotope's RX. I think you can download a trial version to see how well it would work.
Last, you could actually go in a pencil-tool edit all of the clips. One thing I've noticed is that when audio recorded on a lot of video gear clips, it tends to have a "wraparound" type distortion. That is, when the signal clips at 100% positive, you'll see a spike jump to 100% negative. While it's tedious, I once had to go through 25 minutes of audio painstakingly drawing out all of the wraparounds. The final result sounded just fine.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Vocal Distortion? allisvanity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 05-13-2003 12:40 AM
vocal distortion sharkster Tips & Tricks 11 05-02-2002 09:16 PM
Vocal Distortion ReniuR Tips & Tricks 9 06-25-2001 02:24 PM
Vocal distortion. Conscious Structure Tips & Tricks 6 01-09-2001 09:39 AM
Vocal Distortion Conscious Structure Tips & Tricks 6 05-19-2000 01:02 AM
