Old 09-02-2007, 02:32 AM
HerbD HerbD is offline
Default \'Structure\' does not appear on my plug-in list
I'd love to try Structure Free out, but can't add it to an Instrument track.
I down-loaded and ran the installer for Structure Free, without any problems.
During the ProTools start up sequence, 'Structure.dpm' is in the list of PlugIns being loaded, though it takes longer than the others.
Sarting from an empty project file, I create a stereo Instrument track.
When I add an insert, 'Instrument' does not appear in the 'multi-channel plug-in' sub-menu. 'Instrument' does appear in the 'multi-mono plug-in' sub-menu, but its only entry is 'Click'
Is there any other way I can tell if 'Structure' Free was loaded OK? Or what the problem could be?
I am using ProTools M-Powered v7.1, with a FastTrack Pro.
Dell Inspiron 8600, with 1 MB RAM, Pentium M, Windows XP.
Any suggestions about what I should try next?
Herb
Old 09-02-2007, 02:51 AM
Default Re: \'Structure\' does not appear on my plug-in list
I tried the trick that some of the Drag 'n Drop threads mentioned, apparently from Digi Tech Support:
I trashed the files in the folder 'Program Files/Common Files/Digidesign/DAE/DAE Prefs'
When I started ProTools again, 'StructureFree' appeared in my inserts list.
Hope someone else benefits from this post.
Herb
Structure 1.1 outs don't list on tracks I/O tabs justNotz Virtual Instruments 2 11-21-2012 10:23 AM
Structure 1.1 Patch List Kronos06 Virtual Instruments 2 01-06-2012 01:06 PM
Goliath Patches In Catagories List Within Structure salmonsound Virtual Instruments 2 03-04-2008 01:27 PM
Library for Structure? can we make a list of what works? Jeff E Virtual Instruments 4 09-15-2007 05:51 PM
Structure Patch List 14choirs Virtual Instruments 3 07-12-2007 06:42 PM
