  #1111
Old 05-23-2008, 01:36 PM
mykhal c's Avatar
mykhal c mykhal c is offline
Default Re: Best Core 2 Series Desktops-Results and Specs
you should have a disc with your ASUS mobo with all the drivers needed
yea but typically stuff is out of date and such and want to install extra crap along with it, try to keep it slimmed to just the basic needed drivers.
i understand. well what i did on my build was get it up and runnin' then i went into DEVICE MGR, looked for the devices that had '?' besides them and installed the drivers from the cd that came with the mobo. this keeps it to a minimum and does NOT install all drivers nor utilities from the mobo cd then if you want to update or change anythin' you can do so but at least you're up and runnin'. and typically, unless there is a fix that i need, i do NOT install the latest and greatest of anythin'!!! again, unless there is a fix i need
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #1112
Old 05-23-2008, 03:56 PM
cool, that is prety much what i did xcept i got the device drivers off the web. just was not sure if there was anything different i needed to get. so far so good
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
  #1113
Old 05-23-2008, 07:56 PM
SixChurchStreet SixChurchStreet is offline
Any real difference between the P5K and the P5K Pro?? Newegg has the Pro model for an extra 2 bucks.
kip
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM El Capitan | 2011 MacBook Pro 2.0GHz 4-Core i7 8GB RAM El Capitan | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2018 | Studio One 3.5
  #1114
Old 05-24-2008, 05:47 PM
thanks for the suggestion... i placed my NewEgg order!
Q6600
Asus P5K
4GB (2 x 2GB) G.Skill Ram
Can't wait to see the difference. I did the D-Verb test for kicks with my current Athlon X2 939 3600+, and I got a whopping 46 D-Verbs!! lol.
  #1115
Old 05-24-2008, 08:59 PM
sunburst79 sunburst79 is offline
I like to update/Install the drivers from the device manager, that normally keeps the bloatware to a minimum since it only installs the drivers in most cases. I would hit nVidia or ATI for the latest reference drivers for your video card. Then ASUS for the latest LAN, Chipset, Soundcard drivers etc. You will usually need to install the LAN driver thats on the disk in order to get the LAN port working- or at least I did. You will also need to run the Intel Chipset INF utility from the CD menu as I recall. The rest of the drivers can be updated via the device manager method.
You did good or at least you did it the way I would recommend.
I never had any problems with the included drivers or any updated ones for that matter.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
  #1116
Old 05-25-2008, 07:01 PM
zuma zuma is offline
Hi all,
Has anyone built a system with an ASUS P5K/EPU? Looks like it has some cool power saving features, but after reading the first 30 or so pages of this thread I'm scared to buy anything other than a standard P5K for fear of it not being compatible.
  #1117
Old 05-25-2008, 08:29 PM
Hi all,
I think I would avoid it since its new and unknown (with Pro Tools) and once you disabled Speed Step all of the motherboards power saving features are kind of moot. Stick with something thats working and plant a tree if you would like to do something nice for the environment. Turning out the lights when you leave the room would probably save more energy in the long run.
Scott
Core 2 Specs Page
  #1118
Old 05-25-2008, 08:55 PM
mykhal c's Avatar
Hi all,
  #1119
Old 05-26-2008, 02:06 PM
i am getting this error when i try to run my "safely remove hardware" i get this error.
an exception occurred while tring to run "shell32.dll,Control_RundLLhotplug.dll"
i have went through all the drivers including the inf, and everything listed i should have installed driver wise and not sure, never seen this before. i did find an app online to disconnect usb devices only and works fine. also in my computer when i right click on a drive and try to eject it will not do anything. not sure what could be causing this>???
pro-tools-pc.com
Intel I7 6800k
Win 10
  #1120
Old 05-26-2008, 03:06 PM
mano111 mano111 is offline
PT will "take control" over any removable media while its running. Either quit PT and eject the drives, or in PT go to window/workspace and right click the drive then choose unmount.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
i7 Builds - Specs and Results mykhal c Windows 6783 10-03-2019 06:08 AM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 05:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 02:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 02:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 06:51 PM
