what chipset works with 1155 socket?
1155 socket seems to be the easiest to find.
Will it work with pro tools 10 ?? |
Re: what chipset works with 1155 socket?
You do at your own risk, LGA 1155 has proven to be of a little trouble with Pro Tools. You would be better off using LGA 1366 or the newer LGA 2011.
Aaron Mulqueen - 001 HD Native |
My sentiments exactly^^^^^^
Unless you are building a Hackintosh.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
True on paper, but my Hackintosh attempt was a failure(what I built for in the first place)
I'm surprised it's even allowed mention on these forums.
Thanks all.
Just feel overwhelmed. Ray |
1155 is the easiest to find because it's the "consumer" chipset. The reason why it generally isn't approved for Pro Tools is because 1155 socket CPUs have on-die integrated graphics processing which isn't supported for Pro Tools.
Personally, I don't have a problem with it, but it may have something to do with having a motherboard that allows me to turn off the GPU completely and let my dedicated card do all the work. 2011 and 1366 socket CPUs don't have on-die graphics and therefore don't need extra tweaking, but they are considerably more expensive and less readily available.
Dism,
Thanks! That was the answer I was looking for. In my media streaming I need the built in graphics and thought it did not consume cpu overhead. My next question is why NVIDIA "Quadro" boards?? Thanks, Ray |
Integrated graphics is often a show stopper for Pro Tools. Almost any graphics card is going to work fine. nVidia is preferred, but many are using ATI cards as well. Not listed doesn't mean they won't work, only that they are not tested. Quadro are tested and approved. My 2 machines run $50 GeForce cards without issue. nVidia seems to do a better job on drivers
Anyone Having Success With 1155 Socket? | johnjm22 | Windows | 8 | 12-08-2012 03:37 PM |
Any MB with 1155 socket that can support original PCI HD cards? | David Sandwisch | Pro Tools TDM Systems (Win) | 53 | 06-27-2012 08:00 PM |
Surprizing, but PT works with the ol' ServerWorks Chipset | JPS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-13-2008 08:26 AM |
USB-2 w/ Oxford 922 chipset works! | K-Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-13-2004 11:25 PM |
Is chipset Kt133A the only one that works with digi 001? | LuísBrazil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-03-2002 02:04 PM |
