Old 09-18-2012, 12:30 AM
mtung mtung is offline
Default 10.3-Updater sub-program crashes at PT startup
Hello,
At the end of the launch process of the ProTools 10.3 app (fresh updated install from PT 9HD, also with OSX 10.6.8), the updater sub-program is crashing. After clicking on the crash log, it disappears and then PT runs as normal. I guess everything is running OK, but I don't think this is supposed to happen. I tried searching for other threads about this but found none. Does anyone know why this happens?
mike
Old 09-24-2012, 08:07 PM
TheStudioGuy TheStudioGuy is offline
Default Re: 10.3-Updater sub-program crashes at PT startup
Same behavior here. Fresh install 10.3, OS10.6.8 Updater crashes upon start. Click through crash report and rock on. No problems......
JP
Old 12-06-2012, 04:42 PM
Baracas Baracas is offline
Same here too... Has this been resolved yet???? Just started using PT10 updated from 9..... Running OSX 10.8.2...
Works fine after acknowledging the OK button... but obviously it is not "normal" program behavior.
Peace Out
Old 12-06-2012, 05:16 PM
DigiTechSupt's Avatar
Post Re: 10.3-Updater sub-program crashes at PT startup
Did you install over an older version (instead of doing a clean uninstall, then installing 10)?
Please see http://avid.force.com/pkb/articles/e...e-update-error for more info.
Avid Audio Tech Support
Support FAQ
Old 12-06-2012, 05:56 PM
Thanks for the link... I will give it a try... and post results... Ciao
Take Care
Old 09-03-2013, 04:06 AM
jes's Avatar
jes jes is offline
wow, that's just the dumbest. Really? Uninstall and reinstall just for one little library? Can't we just find it and replace that file? There must be a better way of dealing with this.
http://www.jonathansegel.com
Mac Pro Nehalem 2.8Ghz Quad 32GB RAM
Macbook Pro 2.8Ghz 16GB RAM
PT 2020
UAD-2 Apollo Quad, PCIE and Satellite
Software Updater crashes on open wesm macOS 2 10-20-2012 09:41 PM
pt 8 le mixer plug ins crashing program at startup pounceinternational 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 26 12-31-2008 06:46 AM
Crashes at startup HELP PLEASE! I am sad. scoobydoo Pro Tools M-Powered (Win) 1 02-28-2008 03:12 PM
PT LE 5.1.1 Crashes On Loading Program Doc H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-01-2001 10:47 AM
