Old 10-12-2011, 04:40 PM
BtotheZ26 BtotheZ26 is offline
Default Pro tools LE 7.4 Workstation to Mbox question
I have the Mbox2profactory
I the original yamaha Motif61 with instrument and midi cables all hooked properly
I can't get pro tools to trigger the motif when i hit record play on the transport.
Is there a setting on the keyboard/pro tools that i have to set/change to get this.
I had to reinstall it for my new computer so i know im close but it's not going yet...I am getting a signal on the meter bridge from the keyboard.
Old 10-12-2011, 08:27 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Pro tools LE 7.4 Workstation to Mbox question
I'm assuming you mean a signal on the midi track.
Have you assigned the output selector on the midi track to your Motif61? If it isn't showing up as an option then you'll have to set the Motif up in the Pro Tools>Setup>Peripherals>Midi Controllers menu.
You'll also then need an Instrument/Audio track for the return signal with the input selector assigned to the Motif (or just select 'All'). If you use an audio track record enable it to hear the signal.
The Pro Tools Reference guide tells you how to do this.
Edit: You can of course just use an Instrument track and record midi straight to that track.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Pro Tools MBox Mini Static on my HP Z600 Workstation Brian Valentine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-01-2011 03:05 AM
Dell Workstation for Mbox? DWAGS1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-14-2010 07:18 AM
Mbox 2 Mini Workstation (Educational Edition) 2009 rockinr0ll 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-30-2009 04:36 AM
Mbox ok for Mac Workstation? FINKSTONE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-06-2007 10:12 AM
Quick MIDI question for those with workstation and modules.. Captain_Pants 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-03-2002 09:47 AM
