Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-17-2008, 08:14 PM
soopafatkid soopafatkid is offline
Default Any way to eliminate cut/paste edit clicks?
I'm running PT Academic 7.3.1 on a Mac OSX 10.4.10. Is there anyway to eliminate cut/paste edit clicks (for example: edit a long passage down to 4 bars and then duplicate it and make a loop out of it. It matches up with the metronome so I know it was a clean edit but when ever it goes over the break it clicks or pops)? Any help is appreciated.
Old 09-29-2008, 03:44 AM
bradwarren bradwarren is offline
Default Re: Any way to eliminate cut/paste edit clicks?
Maybe try zooming in on your audio, and edit at exactly the point where the sine wave crosses from above to below- and match your desired region at exactly this point. You can also use the pencil tool here to make the lines match as closely as possible.
Old 09-29-2008, 07:27 AM
darkman darkman is offline
use fades
002r PT8.0 XP Pro
Mainboard : Intel DP35DP
Processor : Intel Core 2 Quad Q9450 @ 2666 MHz
Old 09-29-2008, 04:07 PM
Raynald Nadeau Raynald Nadeau is offline
Zoom and do a 8 to 12 samples long crossfade. It's easy with the smart tool. Just enough to remove clicks.
Copy... Paste... Paste... Paste...? accession 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-14-2017 03:46 AM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
Any way to eliminate cut/paste edit clicks? soopafatkid Pro Tools M-Powered (Mac) 1 01-18-2008 01:02 PM
Quickest way to cut paste edit? meandeanmachine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 02-02-2005 08:47 PM
Cut and paste sections of tracks on edit page markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-11-2002 01:38 AM
