Old 10-16-2007, 07:14 AM
jeremiahjobe jeremiahjobe is offline
Default HD Video in Pro Tools?
Is there any HD Video solution for Pro Tools?
Also, does anybody know of a way to use the V10 on an Avid Unity Network running Unity 5 and the PT machine running 7.3.1?
Current config:
Computer:
HP workstation XW8200, Dual Intel Xeon 3.4 GHz with 2 GB RAM, running Windows XP Professional SP2
Digidesign Gear:
D-Command
XMon
Sync I/O
192
Software:
Pro Tools 7.3.1cs2
Avid Unity 5
The basic problem -
Pro Tools 7.3 is not compatible with Media Station | PT, and the V10 is not compatible with HD video.
The reason we upgraded to 7.3 is that Unity 5 is not compatible with 7.2.
Bottom Line:
Is there a HD video solution for Pro Tools 7.3 on an Avid Unity Network running Unity 5? Or for that matter, is there ANY HD video solution for Pro Tools that you can actually buy and that actually works?
Or is there even a way to still use the V10 in the SD environment on Unity 5 running Pro Tools 7.3?
Is there anybody successfully working with Unity 5 and Pro Tools?
Thanks - jeremiah
Old 10-16-2007, 10:24 AM
budster budster is offline
Default Re: HD Video in Pro Tools?
I believe that the new Video Satellite will address this in PT7.4. Check out the info on Avid/Digi's site.
Buddy
Old 10-16-2007, 12:09 PM
audiogeek1 audiogeek1 is offline
V10 works with 7.3 but media station is no longer compatible. As for Unity 5 I am not sure. I would think that V10 is compatible because it is the same thing pretty much as the Adrenaline Bob.
We are still using 7.2 because we need Media station. And we are still on Unity 4.12.
Hope it helps.
As for the new satalite option I do not believe it can do HD video considering it only works with MOJO and MOJO SDI. There is no HD option for MOJO. I could be wrong but that is what I understand.
Mike
Old 10-16-2007, 12:50 PM
Noiz2 Noiz2 is offline
Probably not what your looking for but you can run HD video on a second (or third) computer monitor. There are cards that will do HD out of QT and that should also work but I'm on a Mac and don't know what is available for the PC. If your looking for something from Avid/Digi...? the history there has not been great for video solutions.
www.scottkouesound.com
SK
Old 10-16-2007, 01:59 PM
Thanks for the replies and good information.
My understanding is that video satellite will do HD, but the problem with video satellite is that it doesn't exist (at least not yet). I'm going to try and see if it's possible to get my editors to export a file that will still work with the V10 and Unity 5 and Pro Tools 7.3.1... we'll see. I'll just have to continue working in SD and using QuickTime .mov exports for HD if that works, but better than nothing.
If anyone had any information on this - it's appreciated.
Thanks -
HTML code is On
Video: is it possible to make "cuts" to Video in Pro Tools? Angelo of Onello macOS 14 01-14-2015 06:37 AM
Pro Tools 9 and Video Legion6789 Pro Tools 9 1 07-17-2012 10:35 AM
Pro Tools 9 Video ickeruss Pro Tools 9 1 05-05-2011 03:41 AM
Sharing a video in same session for ADR (video in booth and video in control room) Boogie457 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-01-2010 04:52 PM
pro tools and video--turning video into a quicktime movie? ncw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-01-2008 12:50 AM
