Old 08-04-2004, 06:24 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 6.4cs6 Plug-In Update
For Pro Tools 6.4 TDM and LE systems on Mac OS X and Windows XP
All 4 downloads are available in the Support-> Downloads-> CS section:
http://www.digidesign.com/download/cs
What's Fixed in Pro Tools 6.4cs6?
Certain automation parameter data of certain plug-ins are lost when read by Pro Tools 6.4 if the automation was written using Pro Tools 6.2.3 or earlier (Item #51570)
  • Sessions created on Pro Tools 6.2.3 or earlier will lose certain plug-in automation data when opened on Pro Tools 6.4.
  • Sessions created on Pro Tools 6.4 (without this update) will lose those same automation parameters when opened on Pro Tools 6.2.3 or earlier, or on upcoming Pro Tools versions.
In order to maintain compatibility with prior and future releases of Pro Tools, we highly recommend that all Pro Tools 6.4 customers install this update.
Since Pro Tools 6.4cs6 only updates plug-ins, customers can install it over any version of Pro Tools 6.4. However, Digidesign recommends that all Pro Tools 6.4 users first update to Pro Tools 6.4cs5, and then install Pro Tools 6.4cs6.
Please take note of each plug-in’s affected automation parameters listed below.
  • If you have not automated any of the below parameters in Pro Tools 6.4, you should run this updater now.
  • If you have written these parameters in any Pro Tools 6.4 sessions, you should make a copy of your plug-ins folder and keep it on your desktop. Then run the Pro Tools 6.4cs6 Plug-In updater. Your active plug-ins folder will be updated, but whenever you need to open a session containing the incompatible automation parameters, you should swap plug-in folders with the old version on your desktop. Be sure to swap back when you are done so that all future sessions remain forward and backward compatible. Be sure to keep notes with any Pro Tools 6.4 sessions that have been archived as to which versions of the plug ins are required. The plug-ins folder is located at (Startup Drive)/Library/Application Support/Digidesign.
....Additional details in the included Read Me documents and on each of the 4 download pages
Administrator
Old 08-05-2004, 01:18 PM
drguitar drguitar is offline
Default Re: Pro Tools 6.4cs6 Plug-In Update
....i love pro tools but we shouldn't have to do this plugin folder swapping and keep track of session versions 6.4cs5 and 6.4cs6.....it's just too much, gonna cause headaches for a lot of people
iMac 2017 4K Quad 3.6 GHz i7
32 GB RAM
Presonus 1818VSL
PT Ultimate
Old 08-05-2004, 03:04 PM
Baracas Baracas is offline
Thanks...This 6.4cs6 update finally got Pro Tools running on my Mac 10.3.4 again without continuous "unexpected quits". Thought I was left out in the cold with my Digi 001.
Ciao
Old 08-31-2004, 08:16 PM
zootalors zootalors is offline
I just installed the cs updates for the first time; for ProTools 6.4.
How do I see what version of ProTools I have now - it still shows version 6.4 in the "About" page. Shouldn't it now say it's version 6.4cs6 (or cs7, or whatever?).
Love ProTools by the way, it works for me!
Powerbook G4, OSX 10.3.4
002 Rack
Pro Tools HD 7.4cs6 Update for Mac OS X (Tiger) Avid Technical Alerts 0 06-24-2008 06:10 PM
Pro Tools 6.4cs6 Plug-In Update Avid Pro Tools TDM Systems (Mac) 9 09-27-2004 02:46 PM
Pro Tools 6.4cs6 Plug-In Update Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-04-2004 06:25 PM
Pro Tools 6.4cs6 Plug-In Update Avid Pro Tools TDM Systems (Win) 0 08-04-2004 06:23 PM
Pro Tools 6.4cs6 Plug-In Update Avid General Announcements 0 08-04-2004 06:21 PM
