Old 09-26-2020, 10:27 PM
josoro505 josoro505 is offline
Default Bluetooth Output Woes
I searched FAQ, I got a lot of hits relating to ear buds, bluetooth, and output, but none regarding this simple issue:
I cannot get ProTools to output to my ear buds. I thought it would be in settings....configure.....yada yada.
Please advise
Old 09-26-2020, 10:37 PM
Ben Jenssen's Avatar
Default Re: Bluetooth Output Woes
Check out this:
https://rogueamoeba.com/soundsource/
Great app for audio control on mac. I recommend it. PT friendly.
Life-long audio enthusiast and small studio owner, now retired.
Mac mini, quad core i3, 3.6 GHz (Late 2018), 16 GB RAM
128 GB internal (2500/650 Mbs r/w)
1 TB external (425/425 Mbs r/w).
Focusrite 2i2 3rd gen, Dynaudio BM6's, Command 8, a couple of mics.
Pro Tools 2020.9.1, Mac OS 10.15.7.
Old 09-26-2020, 11:26 PM
I bit the bait again.
Fake post. Some bot thing. First post.
Idiot me.
Old 09-27-2020, 10:58 AM
I don't get what you are telling me.....what bait? What bot?
Should I consult the link you posted? I am not using Mac.
Cheers
Old 09-27-2020, 12:10 PM
Please advise
Pro Tools wants to work with an ASIO interface that provides inputs and outputs in a single device.
What is the main interface you are using?
Your bluetooth earbuds have three main issues.
1. they won't natively support ASIO. You might be able to get around this using ASIO4ALL. If you also have an interface being used for inputs and try aggregating that with the ear buds then you are likely in a world of worse hurt with reliability and clocking performance. ASIO4ALL which you can read about online, is a work around that is best avoided...get an ASIO interface instead.
2. The tendency for the ear buds to connect/disconnect will throw Pro Tools for a loop, either when it starts it will not see the device, or if while operating then Pro Tools will want to shutdown or worse. And if this happens and even if you can get ASIO4ALL to work you need to be very careful when starting up Pro Tools to always hold down the N key and select the ASIO4ALL wrapped or aggregated headphones as the playback engine.
3. One of the common Pro Tools optimizations to improve systems reliability is to disable bluetooth... so I would again be avoiding this idea.
What you should have is a proper ASIO audio interface and a wired pair of headphones or ear buds (or even better nice IEM style earphones) connected to that interface.
Old 09-27-2020, 01:02 PM
@Darryl Ramm
Now THAT'S a response I can understand!
Thank you very much for the input in helping my output.
Would this work?:
https://www.fullcompass.com/prod/507...caAnMwEALw_wcB
Old 09-30-2020, 11:30 AM
daeron80 daeron80 is offline
This might work:
https://audre.io
It's a plugin that goes on your master fader (any fader, actually, but if you want to hear the full mix, the master fader) and sends audio out to any iOS device instead of the interface outputs. Works both directions, so it's useful for a number of things. I use it mostly to hear how mixes will translate to personal device speakers and headphones. Love it because I can make mix adjustments practically in real time (maybe 100 ms delay). Makes it super easy to make sure mixes will translate.
I haven't tried it with earbuds connected to the phone via bluetooth, but I don't know why it wouldn't work. Probably a more noticeable delay.
David J. Finnamore
Nyquist was right.
PT 2020.9.1 Ultimate | Omni | macOS Mojave
PT 2020.9.1 | Saffire Pro 40 | Win10
Bluetooth!! davemartone Pro Tools 12 5 10-16-2017 12:24 PM
Output woes. lode Post - Surround - Video 6 01-27-2015 10:51 PM
Output to Bluetooth Headset? MarkhamMax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-26-2013 04:47 PM
Bluetooth and PT9.0.1 rinconenclave macOS 9 01-28-2011 11:34 AM
Bluetooth with le? midiman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-14-2006 11:32 PM
