error 20700 while translating tracks
I've seen several threads (on this site and others) relating to this issue, but so far none of the advice I've tried from those threads helps.
A session file which had previously behaved normally, I am suddenly getting this error when saving: "Could not save as [session name] because (20700) while translating Tracks." There is also a similar error when auto-backup tries to save a copy. I have tried: trashing preferences, disabling plugins, going back to an earlier version, checking disk permissions and file system integrity. Does anybody actually know what the error number 20700 refers to? Maybe if I knew what specifically the error is, I could figure out a solution. |
Re: error 20700 while translating tracks
Hmmm, never seen this one I do have 2 suggestions for you to try;
1-Create a new blank session at a different sample rate(IOW, if the messed up session is at 44.1k, make the new session 48k, or vice versa). Now Use the Import Session Data command and check the box to use SRC(Sample Rate Conversion). This will re-write all the audio files and MIGHT give you a working session. 2-Hold the SHIFT key while opening the session. This will make all plugins inactive(no settings are lost). If this allows the session to open and be saved again(I would go to File>Save As>rename to something like "songname_noplugins"). If this works, you may have a corrupt plugin(likely a 3rd party plugin and not any stock stuff). Activate a batch of plugins and see if the problem comes back
I was in the middle of editing when this exact same thing happened to me. I saved a few times previously without any issue. I got an error related to auto-backup and now I can't save at all. Maybe corruption? Does anyone have a suggestion that might allow me to save without losing all my edits? Obviously, I could re-boot, etc. and hope it goes away, but my progress would be lost. Thanks!
Just faced the same problem !
It is because of a plugin, Accusonics Happy Placer. This was an April's fool, it is a plugin which displays jokes about musicians... But the error because of it is not a joke... I made all the plugins inactive, and figured out it was because of this one. I removed it, and I was able to save again ! Hourra ! Tell us if your problem is because of another plugin ! |
This turned out to be a plugin for me also. To anybody else having this problem it seems your first troubleshooting stop should be to disable all plugins. If the problem goes away, then starting re-enabling plugins until the problem returns. Then get rid of the last plugin you enabled.
SOLVED! I had the same problem yesterday / big sur / pt ultimate 2023.9, and after reading various post, I found solution. let this be a hint for other desperate people. look for possible plugin with kind of nag screen reminder, i found that one plugin I installed recently (i had it on previous computer and it was needed for opening some backup session), was in pre authorization mode with opened nagscreen, which prevented any save or save as or even save copy as. once i authorized it, problem with 20700 disappeared. In my case it was Impulsive, it had kinda open small authorization window, which prevented disabling or saving. But it can be probably any other plugin asking for some serial or so. Hope this will help someone.
Could Not Complete While Translating Tracks | tromixedthat | Pro Tools 12 | 0 | 11-24-2016 10:13 AM |
Auto UPdate Error (20700) lost 18 minutes of work | john1192 | Pro Tools 12 | 0 | 06-13-2016 03:06 PM |
20700 error | Idealmusic | Pro Tools 12 | 1 | 04-03-2016 05:45 AM |
Could not complete open session because error translating tracks | spiritfallrecording | Pro Tools 10 | 3 | 01-21-2014 08:31 PM |
