Old 04-18-2005, 03:08 PM
Farmer Dave Farmer Dave is offline
Default More 6.9 routing errors (5.1 busses)
I just panned a sound into the Right Surround, and it goes to the Left Surround on the bus. It's not a patch problem here in my studio either. You can see the panner go to the right rear, but the level on the left rear 5.1 aux track is where it goes.
Old 04-18-2005, 03:44 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: More 6.9 routing errors (5.1 busses)
I just tested this on my system and i'm not getting the problem! going through a 5.1 bus and going direct to the 5.1 master bus.
G5 2g dual 0S10.3.8 PT6.9 HD3
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-18-2005, 10:18 PM
cjguitar cjguitar is offline
We're definately seeing something similar, if not worse here. We're working on a temp mix, and center channel dialog will suddenly go out completely, or both front chanells, or we'll get random noise (pink or other) in various random channels. We think it could possibly be related to the Waves RenVerb (Version 4.x). Are you using Waves at all? We have to go to the I/O Setup and disable the main out, then go back and enable it again, and it seems to work for a while. We might have to go back to 6.7 if we can't figure this out.
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 04-19-2005, 09:17 AM
I've got Waves 360 Mixdown on my Master Fader 5.1 output, but it's inactive. My problems are coming before it hits that plug-in. Audio track to a 5.1 Aux, with no plug-ins on either.
I actually can't reproduce this panning error now, but I have another post that sounds more like the dropping out problem you're having.
Maybe we should continue this conversation there.....
6.9 Bus errors LINK
Old 04-19-2005, 09:25 AM
crizdee's Avatar
Hi
Waves version 4.x? this may be your problem Chris? i thought all waves were at version 5 now!!
Sorry Farmer Dave! didn't mean to go off subject, let me know if there is any test i can do for you.
Regards
Chris
Producer, Engineer,
www.ukmastering.com
busses re-routing in PT 10 Jperkins Pro Tools 10 1 10-15-2012 12:23 PM
Routing busses working goga Pro Tools 9 2 02-08-2011 04:09 AM
Quicker Routing through Busses Dizzi45Z Pro Tools TDM Systems (Mac) 26 02-02-2010 09:48 PM
no input for mono tracks/playback errors/busses brianf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-13-2005 05:09 PM
problem routing to busses sauceman Tips & Tricks 2 12-17-2003 10:44 AM
