Old 01-18-2005, 01:24 PM
GoneIndie GoneIndie is offline
Default Best Way to bounce tracks with effects/plugins
Hey All,
Using PT 6.2. Running out of DSP and need to bounce effects/plugins to free up DSP. Whats the best way? Use the Bounce To Disc function under the File menu? Bus the track to another? Set output of one track as input to another? Using bounce to disc and bus method seems to raise the volume higher than the original.
Have tried seraching the DUC, but the search is not working it keeps returning all posts starting from most recent.
Thanks all
Old 01-18-2005, 04:17 PM
Kurtstudio Kurtstudio is offline
Default Re: Best Way to bounce tracks with effects/plugins
If your volume of the is set to unity 0 , your volume should reamin the same as you print it( bound to disk) make sure you assign all tracks and effects to bound and mute all other tracks. Also make sure you have removed any Master Output insets, as they will effect your bound level and sound. Check Import after bounce and you should be OK. Spot it and it should return to the original time stamp, if not uncheck auto spot regions and repeat the same.
Later, Kurt
[email protected]
Intel duel Quad core
PT 8.0cs3
HD4
D Command / D control
Old 01-18-2005, 04:20 PM
also, if you bus to another audio track and print, you aren't really bouncing to disk and you will have a 10 ms offset to deal with, by nudging the track ahead 10 ms you will remain fase locked, I prefer to bounce , that way there is no timestanp difference.
Later, Kurt
[email protected]
PT 8.0cs3
HD4
Old 01-18-2005, 04:35 PM
Steve MacMillan Steve MacMillan is offline
That would be 10 samples not milliseconds.
STeve
macmandigital.com
Old 01-18-2005, 08:23 PM
john1192 john1192 is offline
even with ADC ?
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-18-2005, 09:58 PM
even with ADC ?
ADC will put it in the right place.
STeve
macmandigital.com
Old 01-19-2005, 12:03 AM
my bad, sample is correct!!
Later, Kurt
[email protected]
PT 8.0cs3
HD4
Effects Bounce. tommydigiowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-08-2011 07:48 PM
bounce with external effects karaho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-03-2008 09:08 AM
Adding effects during a bounce GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-20-2005 10:02 AM
Bounce to Disk, No effects? geordieboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-06-2001 08:31 AM
Outboard effects don't bounce to disk? Kerry C 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-08-2000 12:54 AM
