Old 03-12-2015, 05:45 AM
Rob Hannon Rob Hannon is offline
Default Advice for a newbie
Hi Guys
As a newbie I appologise if this is posted in the wrong section!
I'm looking for advice in setting up a PC upgrade in readiness to swap from being a cubase user to a Pro Tools user.
My intended upgrade is:
ASUS z97 delux MB
i7 4790 processor
32GB Ram
250GB PCIe M.2 SSD
Further 250GB SSD
to add to exisiting:-
2 x 500GB HDD
Motu 24 i/o with PCI card
I have undertaken all the exporting process from cubase in readiness to import into PT 11 all of which is stored on 1 of the 500GB HDD's.
I intend to clean and format the other HDD, which is currently my C: drive hosting OS, programs, VST's and plug ins before I carry out the physical upgrade and new installation of Win 8.1. (and yes I will backup the files before I start)
My thoughts are to partition the M.2 SSD and load windows 8.1 to one partition and Pro Tools 11 to the other partition.
I thought I could then load VST's and plug ins to the other SSD.
My question is do I use the second SSD to save my projects and associated .wav files or use the HDD's? I've read, and am a bit confused over the writing limitations of SSD's. My concern is as you are recording new projects you may make many takes of a track before pinning it, which means multiple writes to the SSD.
You may also think my use of the M.2 is wrong so am happy for all feedback.
I am so looking forward to getting to know Pro Tools and taking advantage of all the features it has over my old Cubase DAW.
Hope you can help
Rob
Old 03-12-2015, 07:05 AM
Default Re: Advice for a newbie
Pro Tools needs to be installed on the C: partition. YMMV, but I would not partition any drive that is 250GB or smaller
Old 03-12-2015, 07:15 AM
Thanks Dave
Take your point re partitioning.
If I put the OS on the m.2 could I not assign this the C: drive in BIOS thus allowing me to also load pro tools to the M.2?
Old 03-13-2015, 06:10 PM
zedhed's Avatar
zedhed zedhed is offline
Install Pro Tools on the same drive/partition as the Operating system (C:) installing it as one would with any program.
Then record to separate drive.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 03-14-2015, 07:25 AM
Bill Denton Bill Denton is offline
And there is really no need to partition drives (unless you are using multiple operating systems)...on spinning drives it actually degrades performance.
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Newbie in need of some Pro advice djoeyd77 Post - Surround - Video 8 09-27-2010 04:24 PM
Newbie Advice ironfin ICON & C|24 6 08-20-2008 02:08 AM
Newbie needs some advice - but not what you think. I need... RiffWraith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-10-2008 12:04 PM
advice for a newbie 40bends 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-23-2007 09:59 AM
newbie seeking advice warmseth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-28-2004 10:02 PM
