Old 10-15-2006, 12:58 PM
Woodan Woodan is offline
Default noise in my recording?
When I record I get a noise when I raise my voice!
I have the mbox2 and macbook. there's been trouble with this [bleep] since the day I bought it.
I've checked the vomule and it doesn't go all the way up in the red area??? what shall I do?
If I turn the volume down it helps, but I just can't guess... were to have the volume... should I?
is it something with the volume? could it be the microphone? something in the program? the mbox?
Please... I want to destroy things overhear... HELP, say something to calm me down.
I payed so much money just to be angry!
Old 10-15-2006, 05:32 PM
M.Brane M.Brane is offline
Default Re: noise in my recording?
The first rule of audio is that if it sounds good it is good. If it sounds better when you turn it down perhaps you should trust your ears, and not the notoriously iffy PT meters. I track stuff with peaks around -12dbFS myself. Things sound a lot better to me that way. Cheap Op-Amp based preamps don't like to be overdriven.
You can always make things louder in the mastering stage. In fact it's better to do it that way. In tracking, and mixing it's all about headroom.
Old 10-16-2006, 07:39 AM
cfb25 cfb25 is offline
what kind of noise are you talking about? There are a couple thigns that could cause this.. More than just the pres... Is it a distortion type noise.. or like an interferance type noise? Is it high, low, or al over?
Chris Beaver Music
www.myspace.com/chrisfrankmusic
The Note Music
www.myspace.com/thenotemusic
Dual 2.0Ghz PPC 3gb Ram, Digi 002R
Old 10-16-2006, 11:43 AM
it's only on the loud parts and it crunches like if your volume is to loud.
And another thing is it bad for the mbox 2 to clouse to a speaker?
Old 10-16-2006, 01:19 PM
KingTor KingTor is offline
What kind of mic is it? It could be distortion in your mic, but it's probably in the preamp. I'm a sucker for anyone who quotes Louis Armstrong ("If it sounds good, it is good") so I agree that if it sounds better when you turn it down, then you should do that. You don't have to push the meters up near the top to get good sound in the end.
The mbox's proximity to the speaker shouldn't matter unless the mic is also close to the speaker and there's sound coming out of the speakers as you record, but I don't think that's what you mean.
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 10-18-2006, 04:23 AM
no... thanx dude.
I actually had one more question if you don't mind..
Im getting an external harddriv and I wonder if I should reinstall protools on this harddrive and if so, do I have to reinstall all the plugins to (ik multimedia reason etc.) And if so... how's the easiest way to do it?
Old 10-18-2006, 05:37 PM
You don't need to install PTLE on the external drive. Simply choose it as the place for your sessions/audio files. If it's a large drive you could partition it, and use the first partition for audio, and the second as a backup for your system drive. As long as you don't exceed 75% total capacity you'll be fine.
Old 10-21-2006, 04:42 AM
thanx again...
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? PeterGreen Pro Tools 10 24 01-23-2013 06:38 AM
Recording Noise Art B Incredible 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-19-2006 08:23 AM
Sometimes noise while recording kolo Pro Tools TDM Systems (Mac) 3 07-20-2006 12:23 PM
Recording Noise n3xus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-13-2005 08:49 PM
Noise after recording! Ivann Pro Tools TDM Systems (Mac) 2 08-19-2003 09:28 AM
